Software Archive
Read-only legacy content
17060 Discussions
Startup Script error
jrburciaga
I downloaded the Evaluation version of Intel fortran Composer XE2011 Update 3 for MAC OS X and when the installation program started it stopped almost immediately with the following error.
Could not run startup script
Error while executing the startup script. Make sure that you have write permissions to /tmp folder and /Users/Shared/Library/Application Support/Intel/Licenses folder
Suggestions?
KitturGanesh
The reason you're getting that error is that the composer package creates the license and install log files in the /tmp directory. It looks like either that directory is out of disk space or there's a permission problem. Please rectify the above it that's the case. In addition ensure that the directory /Users/Shared/Library/Application Support/Intel/Licenses also has sufficient disk space and there is no rw permission problem.
Let me know if you still have issues after that?
-thanks,
Kittur
Thongchai_K_
I solved this by creating "Intel" folder inside "/Users/Shared/Library/Application Support/".
Seems like a bug to me :/
