Software Archive
Read-only legacy content
17060 Discussions
Status bar for construct 2 build problem
George_Z_1
https://www.scirra.com/forum/viewtopic.php?f=152&t=124094&p=889417&hilit=status+bar#p889417 as you can understand from here there is a new problem with status bar with construct 2 build. Seems like it is problem in Intel because it works well with phonegapp for example exporter.
I`ve turned on and off statusbar plugin. Turned on and off fullscreen option. I`ve tried for three days any possible solution but it seems like it doesn`t help.
I have latest intel xdk version and construct 2 release 200
George_Z_1
i`m really newbie to code, thats why i`ve used construct but i`m pretty sure that problem is in intel. I`ve builded with old version and all was ok before i`ve updated. Also i`ve just made a build with phonegapp and everything is ok.
Maybe i should add/change something in files? Add something like status bar plugin files?
Konstantin_R_
I also can not find a solution to this problem. Who ever found a solution?
Corey_C_
Within Construct 2, on the start of your first layout, try adding the Browser's "Execute Javascript" action and execute "StatusBar.hide();"
You will need to make sure you add the StatusBar plugin from within Intel XDK.
Konstantin_R_
Thank you very much! it helped me!
Maybe you can tell me how to run admob on windows phone 8.1? Not one plug-in does not show ads on wp, but show on android and ios.
Thank you.
