Software Archive
Read-only legacy content
17060 Discussions
StatusBar plugin not included in build
Gaetan_V_
I try to use the StatusBar plugin to hide the status bar on the different devices, but it simply will not include in the build anymore. It has worked a few days ago, but since then, it will not work anymore.
It works (most of the time) in the emulator, and I can see the plugin added inside the plugins folder. Inside the config files for the different platforms, the plugin is also correctly added.
I've tried to disable/enable the plugin, removing and re-adding the lines in the config files, rebuilding... I'm really all out of ideas. Can anyone help?
Edit: The plugin is included in Android builds, but not in iOS builds...
PaulF_IntelCorp
Not sure why this would be a problem with the iOS builds but not the Android builds. There are a few other mysterious iOS build problems that I've asked the responsible engineer to take a look at. Will try to update this thread with a note when he has figured out what is wrong with those other builds, it might be related.
