Software Archive
Read-only legacy content
17060 Discussions
Streaming Using Events In C#
Mike_J_
Can anyone get the example from the documentation  to work.
When I try it the OnNewSample is never called.
pxcmStatus OnNewSample(Int32 mid, PXCMCapture.Sample sample) {
   if (sample.color!=null) {
       // work on the color sample
   if (sample.depth!=null) {
       // work on the depth sample
   // return NO_ERROR to continue, or any error to exit the loop
   return pxcmStatus.PXCM_STATUS_NO_ERROR;
void CaptureUnalignedColorDepthSamples() {
   PXCMSenseManager sm=PXCMSenseManager.CreateInstance();
   // select the color and depth streams
   sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR,640,480,30);
   sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_DEPTH,320,240,30);
   // Initialize my handler
   PXCMSenseManager.Handler handler=new PXCMSenseManager.Handler();
   handler.onNewSample=OnNewSample;
   sm.Init(handler);
   // Streaming
   sm.StreamFrames(true);
   // Clean up
   sm.Dispose();
Mike_J_
To make my question clearer - does the event handler approach work and if so why do none of the samples use it?
They all create a new thread and run the polling loop there which is what the event handler approach is supposed to do for you.
