Preciso de algo simples e objetivo, reproduzir o audio que chega por um IP:Porta porém no formato AAC, o que fazer? Por favor preciso de ajuda urgente!!!!
- Tags:
- HTML5
- Intel® XDK
Well, I'm slightly unsure whether your question is how to play audio in general vs how to play AAC encoded audio.
In the former case, I'd take a look at the "hello-cordova" sample app and look at the code associated with the "BarkCordova" button as an example. I don't know exactly how/if various codecs work with that Cordova plugin (cordova-plugin-media) but you could try replacing the "bark.wav" file with an AAC file to check real quick.
If that doesn't work, you can try looking at some other plugins like this you could try looking at a plugin like https://github.com/wnyc/cordova-plugin-playerhater.
Let us know if that works or not, otherwise I can look into it more deeply.
Dale
I need something simple and objective, play the audio arriving for an IP : Port but in AAC format , what to do? Please need urgent help
