Software Archive
Read-only legacy content
17060 Discussions
Stuck after updating v2366 -> v2496
Developer_A_1
Just updated from v2366 to v2496. Original project is asked to be converted, but there are many errors.
First some "process.exit()" errors on screen, then restarting XDK a request to upgrade plugins and some errors we cannot state because the window has been closed too soon.
Now trying again to OPEN the previous XDK we have a "ENOEN, no such file or directory"... error. Now we're stuck with
Developer_A_1
...trying to remove the plugin "intel.xdk.device" manually from the ".xdk" file brings this instead:
Pamela_H_Intel
Do you have your projects stored on the same drive as your XDK application?
See: https://software.intel.com/en-us/forums/intel-xdk/topic/594199#comment-1841270
Engineering is aware of this and is working on it.
Developer_A_1
See: https://software.intel.com/en-us/forums/intel-xdk/topic/594199#comment-1...
...reference seems to be about Win: we're using a Lnx platform and anyway they're on different mount point (namely an /opt/... folder and a different /home/... for data), so maybe THIS is the problem (?)
Thank you for your job... we've downgraded back to previous version and using it 'til next upgrade, meanwhile :)
Pamela_H_Intel
So, are your project and the XDK application stored on different drives?
Developer_A_1
well... we could say "yes" considering different mounting points as different drives (the latter term having many meanings depending on the context :))
Pamela_H_Intel
Being in different directories should not be a problem as long as they are physically on the same drive.
But if you are happy with 2366 (other than the much too frequent upgrade messages - we have requested these be minimized), then it may be best to use that temporarily. We are working on several issues, primarily surrounding changes in Cordova and expect to have a new XDK version out very soon.
