Software Archive
Read-only legacy content
17060 Discussions
Sublime text can't use correctly (build 3900)
Ibid_A_
When i save the file using sublime in build 3900 the simulate is not automatically refresh, but the older build can do it. i love sublime, please fix this.
gaston-hillar
Valued Contributor I
Ibid,
You mean you edit code files that belong to a project with Sublime Text while Intel XDK has this project opened. After you save changed made with Sublime Text, Intel XDK doesn't refresh the files that you edited with Sublime Text. Is this what you you report?
gaston-hillar
Ibid,
Ibid_A_
Yes, when i was edited by using sublime text while the projects opened, the simulate doesn't refresh in update 3900.
PaulF_IntelCorp
I will report this issue to engineering. In the meantime, as a workaround, you can use the refresh button on the Simulate tab's toolbar:
