Software Archive
Read-only legacy content
17060 Discussions
Swap on xeon phi
Philip_S_
I have a Xeon Phi card running MPSS Gold update 3.
I want to use swap but mic_virtblk will not load into the kernel
message is cannot find mic_virtblk.
Do I need to use MPSS 3.2.3 to use swap?
TimP
Did you read the article?
https://software.intel.com/en-us/blogs/2013/07/11/avoiding-potential-problems-memory-limits-on-the-intelr-xeon-phitm-coprocessor
I suppose this is a potential hurdle in porting applications which needed a swap partition in the past, but it seems worth while to explore methods to reduce memory and disk usage (although the KNL would seem to change the rules again within 2 years).
Philip_S_
Tried to follow the instructions in the article, but as I said in my original post
mic_virtblk.ko will not load into the mic kernel.
is there something else I need to do first that is missing from the article?
Philip_S_
Also,
This path is not present on my host machine.
        /sys/devices/virtual/mic/mic0
up o
is present but only contains /ctrl and scif
do I have the correct version of MPSS to set up a swap space?  (gold update 3)
TimP
Your contents for that directory appear to be normal even for current MPSS.
TaylorIoTKidd
Unfortunately, your version of MPSS is too old for us to check. (We have no test systems with that old of an MPSS.)
Please update your version. If you still have an issue, let us know and we'll do what we can.
Taylor
TaylorIoTKidd
Oh, and please wait for a few (business) days before updating your version of MPSS.  ;-)
Taylor
Philip_S_
Found this in the rel notes for gold update 3
Intel Tracking ID:  4845954
Affected OS:        All Linux
Description:        [Driver] Virtualization is no longer working for
                    coprocessors
Notes:              Investigating
Is this resolved in the latest version?
Phil Sharrock
Frances_R_Intel
According to the bug tracking system, this issue is resolved and closed as of this release.
Philip_S_
Loaded MPSS 3.2.3.
Still will not load mic_virtblk.ko into kernel, same error as before.
Also when compiling on Phi card the linux command 'ar' (via busybox) does not accept
the -r option, this option is needed when adding items to archives.
Phil Sharrock
Frances_R_Intel
Sorry, I should have said closed as of the MPSS 3.3 release. And I guess I need to update that blog. The complete directions for using a virtio block device are now in the MPSS User's Guide, rather than the readme and some of the directory locations appear to have changed. Sigh.
As far as ar not having a replace option, I can see how that would be painful. I'll look into this.
Philip_S_
Even following the instructions in the MPSS users guide, modprobe mic_virtblk fails to load the driver
I get the same error message file not found/not present
Frances_R_Intel
Uh, oh. I think I know what is wrong. With 3.2 and continuing into 3.3, a number of files which are considered optional on the coprocessor have to moved to rpm files that must be explicitly added if you want to use them. I found mic_virtblk in  mpss-modules-3.3-1.knightscorner.rpm. Under MPSS 3.3, to load these files you need to follow the instructions in section 11.3 in the MPSS User's Guide.
When I use these extra rpm files on the coprocessor, I prefer to follow section 11.3.3, making a directory containing only the rpm files I want uploaded to the coprocessor and including in these the files needed to run zypper on the coprocessor (see section 11.3). That way I can specify the directory name rather than the individual filenames on the micctrl command and not need to rerun the command each time I add or remove files from the directory. If, after I reboot, I log onto the coprocessor and find a directory called /RPMs-to-install, it means the rpm files did not successfully install. In this case, I install the files needed to run zypper and use zypper to check for any unsatisfied dependencies or errors, then fix those.
Philip_S_
Tried to install the suggested rpm file.
Got the message already installed
Andrey_Vladimirov
New Contributor III
Swap on MIC works for me in MPSS 3.3. I only installed the RPMs inside of "mpss-3.3/" and the kernel module. The difference in my procedure versus Frances' article are:
  • The path to the virtblk_file is different in MPSS 3.3
  • I can format the drive from the host
  • If you are changing virtblk_file, you should unload and reload module mic on the host
  • There is no need to modprobe mic_virtblk, it loads automatically if virtblk_file existed when MPSS booted
  • I used an LVM volume instead of a file on the host
Here is the sequence of commands that I used:
[root@c001-n002 ~]# service mpss unload
Shutting down Intel(R) MPSS:                               [  OK  ]
Removing MIC Module:                                       [  OK  ]
[root@c001-n002 ~]# modprobe mic
[root@c001-n002 ~]# mkswap /dev/mapper/vg_phi-lvol0 # Formatting a logical volume for swap
mkswap: /dev/mapper/vg_phi-lvol0: warning: don't erase bootbits sectors
        on whole disk. Use -f to force.
Setting up swapspace version 1, size = 31457276 KiB
no label, UUID=6b0609cc-4b8b-4bc4-8e35-7a0f52260ffa
[root@c001-n002 ~]# echo /dev/mapper/vg_phi-lvol0 > /sys/class/mic/mic0/virtblk_file
[root@c001-n002 ~]# service mpss start
Starting Intel(R) MPSS:                                    [  OK  ]
mic0: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
mic1: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
mic2: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
mic3: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
[root@c001-n002 ~]# ssh mic0
[root@c001-n002-mic0 ~]# swapon /dev/vda
[root@c001-n002-mic0 ~]# cat /proc/swaps
Filename				Type		Size	Used	Priority
/dev/vda                                partition	31457276	0	-1
See also our article on file I/O on Xeon Phi for performance benchmarks: http://research.colfaxinternational.com/post/2014/07/28/io.aspx
Andrey_Vladimirov
New Contributor III
Quick update: I have just tested using a file instead of a logical volume on host. That configuration also worked for me.
TaylorIoTKidd
Phil,
Any update? Did you get it to work?
Taylor
Philip_S_
Yes that worked. swap now available.
now just got to stop the Phi card locking up when most of memory used.
no communication with card after a few minutes.
Phil
David_M_8
Hi, i'm trying to use virtblk with mpss 3.51 but
- no luck using the user guide method
- no luck using Andrey's method above
errors:
/dev/vda - - - No such file or directory
and when doing  [root@mic0 ~]# modprobe mic_virtblk
FATAL: Error inserting mic_virtblk (/lib/modules/2.6.38.8+mpss3.5.1/extra/virtio/mic_virtblk.ko): No such device or address
Is there an updated procedure ? Many thanks in advance !
JJK
New Contributor III
just tried it on my mpss 3.5.1 install and it "just works".
Did you install the mpss-modules package? this RPM includes the module mic_virtblk.ko:
[root@mic0 ~]# rpm -qf /lib/modules/2.6.38.8+mpss3.5.1/extra/virtio/mic_virtblk.ko
mpss-modules-3.5.1-1.knightscorner
Also, make sure to initialize the swap device prior to using it:
[root@mic0 ~]# swapon /dev/vda
swapon: /dev/vda: Invalid argument
[root@mic0 ~]# mkswap /dev/vda
Setting up swapspace version 1, size = 10485755904 bytes
[root@mic0 ~]# cat /proc/swaps
/dev/vda                                partition       10239996        0       -1
Frances_R_Intel
I just double checked on a couple systems that I use and both had /lib/modules/2.6.38.8+mpss<version#>/extra/virtio/mic_virtio/mic_virtblk.ko installed by default. When the mic_virtblk kernel module loads, it creates /dev/vda. What modprobe is complaining about is not that it cannot find the kernel module but that it cannot find the device on the host that is providing the actual swap space. Without that space the module can't load.
So first check on the host to be sure the device you are using exists - /dev/<disk_name>, /dev/<disk_partition_name>, /dev/mapper/<logical_volume_name> or the file name , if you are using a file instead of an actual device.
Make sure /sys/class/mic/mic0/virtblk_file on the host exists and that the content of that file is the full path name to the device you are using.
If the file /sys/class/mic/mic0/virblk_file did not exist when the coprocessor was booted, stop and restart the mpss.
If all that checks out, mic_virtblk.ko really should load.
