Software Archive
Read-only legacy content
17060 Discussions
Systems with TXT/TPM support
marie1987
Hi
We tried to install tboot and we always get IA32_FEATURE_CONTROL_MSR = 9 so the bit locked is fixed at 1.
We have a DQ45CB and we updated the latest BIOS version (0129). IIt is supposed to support TPM,TXT and VT-d.
We are using the ACM Q45_Q43_SINIT_19.BIN and the latest version of tboot (20101005).
How can we provide the BIOS to change the IA32_FEATURE_CONTROL_MSR to enable SMX?
David_O_Intel1
This platform does support TXT and has beentested(though not with that specific BIOS version).
Make sure youhave enabled both the TPM and TXT in the BIOS. Also, be sure topowercycle the system after enabling themto ensure the settings take effect. After doing so,go back in to the BIOSand confirm that both are set.
David Ott
marie1987
I confirm that TXT and TPM are both set in the BIOS.
David_O_Intel1
You should alsoconfirm that VT-d and VT are set in the BIOS. Is it so?
An engineer working with me was able confirm that it works correctly -- as long as TXT, TPM, VT-d, and VT are correctly enabled in the BIOS setup.
David Ott
Mk_S_Intel
1. What are the Mandatory Hardware requirements to Enable Trusted Boot on Intel Systems?
2. Please help me to find list of Intel Xeon and Core Processors which support Trusted Boot
