Software Archive
Read-only legacy content
17060 Discussions
Text colors in dialog boxes
presser
I got a problem with using text colors in dialog boxes. Whereas the color control works so far quite well, there occurs an error when loading bitmap images with the command LOAGIMAGE_W in my QuickWin application. No image is shown. As far as I could verify, this problem arises with applying the command DlgSet(Dlg, idControl, nRGBvalue, DLG_COLOR ). Thanks for helping me.
Jugoslav_Dujic
Valued Contributor II
Hmmmm, first, where does that DLG_COLOR stuff comes from? DFLOGM from CVF 6.6 or some of the ones (XFLOGM) "touched" by me?
If the former, please ignore the sequel :-).
If the latter, I don't recall that there were ever bugs related with memory leaks (which the one you describe looks like). You might try downloading the latest version
from me the workspace to take a look?
Jugoslav
