Software Archive
Read-only legacy content
17060 Discussions
The build failed
Fab_V_
Since last update 2248  i always have :
An error occurred while building the application. Verify your build assets are correct and try again.
No errors, no logs to view, and each plugin line is written as intalled.
Is there a problem with the server or the build ?
Using Cordova Project - Android Build
John_H_Intel2
Have you added any 3rd party plugins? Try removing them and see if the build works without them. This can help determine if there is an issue with one of the plugins you have included.
