Software Archive
Read-only legacy content
17060 Discussions
This is novice programmer seeking help???
sravansai
#include
#include
unsigned int chec=0,lim=0;
char output[20];
FILE *fp;
int power(int a,int b)
int n,c=1;
for(n=0;n {
c*=a;
return c;
int check(unsigned int d,int a,int c)
fp=fopen(output,"a");
int y=0,x=0,n;
for(x=1;x<=c;x++)
for(y=2;y<=lim;y++)
n=power(x,y);
if(d==n)
fprintf(fp,"sum(%d:%d)=%d=%d**%d\\n",a,c,d,x,y);
int main()
unsigned int count=0,MAX,MIN;
scanf("%d%d%d",&MIN,&MAX,&lim);
unsigned int a[MAX],i,m=0,b[MAX],k=0,j=0,c,f;
for(i=1;i<=2;i++)
gets(output);
for(i=MIN;i<=MAX;i++)
a=i;
m++;
j=m;
for(m=0;m<=j-1;m++)
if(a>0)
for(i=2;i<=a-1;i++)
if(a%i==0)
break;
if(i==a)
b=a;
k++;
else
continue;
else
continue;
b[k++]='\\0';
for(k=0;b!='\\0';k++)
b;
/*printf("\\nThe Number of Prime numbers in the given range are.......%d",k);*/
fp=fopen(output,"w");
for(i=0;i<=k;i++)
c=b;
for(j=i+1;j {
c+=b;
m=check(c,b,b);
getch();
Sir this is what the program i wrote and am in a need of ur help that how to give command line arguments and how to use them....i'm just a school student....so please consider this and reply me as soon as possible.
And please give some remarks on the program that is shown above.
Aubrey_W_
To use command line arguments, you'll need to use the version of main() that takes two arguments. You can find an explanation at http://publications.gbdirect.co.uk/c_book/chapter10/arguments_to_main.html
I hope that helps.
Aubrey W.
Intel Software Network Support
