Software Archive
Read-only legacy content
공지
17060 토론
Two bar code scanners
Dziugas_S_
초급자
992 조회수
Hello. I'm trying to implement two barcode scanners to two buttons. The problem is that when I click one button or the other, both scripts for the scanners are activated. How to fix that one button uses one script and the other uses the other script?
Button1:
<a class="uib-graphic-button default-graphic-sizing default-image-sizing hover-graphic-button active-graphic-button default-graphic-button default-graphic-text widget uib_w_52 d-margins skenavimo_tekstas media-button-text-bottom" data-uib="media/graphic_button"
                    data-ver="0" id="scan1" style="position: relative; display:block; float:center; width: 10%; padding-bottom: 10%;
    width: 50%; margin: 0 auto; " onclick="scanNow();">
                        <img src="images/barcode.png">
                        <span class="uib-caption">Check</span>
                    </a>
Button2:
<a class="button widget uib_w_54 d-margins testas icon camera yellow" data-uib="app_framework/button" data-ver="1" id="scan2" onclick="scanNow2();">Scan</a>
Here is the first script:
<script>
        function scanNow()
                //this function launches the QR Code scanner.
                intel.xdk.device.scanBarcode();
            document.addEventListener("intel.xdk.device.barcode.scan",function(evt){
                if (evt.success == true) {
                    //successful scan
                   alert("I'm number 1");
                else
                    //failed scan
                    alert("ERROR");
            },false);
    </script>
And here is the second script:
<script>
function scanNow2()
                document.addEventListener("intel.xdk.device.barcode.scan",function(ted){
                    if (ted.success == true) {
                        //successful scan
                    alert("I'm number 2");
                    }else{
                        alert("ERROR");
                 },false);
        </script>
0 포인트
1 응답
Rakshith_K_Intel
992 조회수
That is cause u have 2 event handlers already fired and the code is rightly executing both event handlers.
You can do something like this:
<script>
var scan = 0;
function scanNow(){
    scan = 1;
function scanNow2(){
    scan = 2;
        if(scan == 1){
            scan = 0;
        } else if(scan == 2){
            scan = 0;
    }else{
        alert("ERROR");
},false);
</script>
0 포인트
응답
