Software Archive
Read-only legacy content
17060 Discussions
Typescript Extension Problem
Namık_Zafer_E_
Brackets 1.9.0-0 code editor has Typescript extension and it works fine but Intel XDK has not. I downloaded one of Typescript extension but Intel XDK editor cannot find format of file and also i cannot change file format to Typescript from bottom bar. There is no Typescript selection.
I know Intel XDK uses Brackets code editor in its core.
How can i add Typescript extension?
PaulF_IntelCorp
Because the Brackets editor inside the XDK runs in a non-standard environment, we are not able to guarantee that ALL Brackets extensions work with the built-in editor. I recommend you use the standalone copy of the Brackets editor to work with your project files, rather than the built-in XDK editor.
