Software Archive
Read-only legacy content
17060 Discussions
Upgraded to Cordova now Google Play does not accept the app
Taha_M_
Hi Folks, I am a newbie with this. Thinking that I can fix the security issue I was getting from Google Play about Cordova, I just upgraded my html app to Cordova. When I try to upload the build to google play, it complains about the package name should be com.somthing.somethingelse and it also says that "Your APK's version code needs to be higher than 12."
Is there a way I can get it to do that?
Hamilton_Tenório_da_
Valued Contributor I
Each compilation has a version code, and the newer must be greater than the older.
I must go to Projects tab, Building settings, and add + 1 in the field content of App Version Code.
Taha_M_
Thanks, that helps with the version number. I still have an issue with" Your APK needs to have the package name com.webcai.lenses."
Do you fill all the fields of these tab?
Are you building Android ou Crosswalk Android?
Taha_M_
I am building Android. I tried changing the name under the project settings to Webcai.lenses and com.Webcai.lenses but that did not help.
Thanks for your help. Taha
Uhn
Do you can attach a print of this tab?
Taha_M_
I just figured it out. I just had to change the app id to that. Thanks for your help.
PaulF_IntelCorp
The "App ID" field is the one you need to set. Did you try setting it to "com.webcai.lenses" all lower case? I don't know if these are case-sensitive, but your message that you quote and what you said you did do not match...
Taha_M_
Thanks you. I figured it out. I also changed the case just in case.
