Software Archive
Read-only legacy content
17060 Discussions
Upload failed Your APK cannot be analyzed using 'aapt dump badging'. Error output: Failed to run aapt dump badging: ERROR: dump
Zsadez_B_
I recently wrote a web based application, built the apk with Intel XDK, and upon publishing got the Error message: Upload failed Your APK cannot be analyzed using aapt dump badging.  Error output: Failed to run aapt dump badging : ERROR: dump failed because assets could not be loaded. What is causing this?
RBang
New Contributor II
Could be an issue with you bot properly signing your apk. See if this helps you - https://www.scirra.com/tutorials/1156/publishing-to-android-via-intelxdk-and-appsigner
