Software Archive
Read-only legacy content
17060 Discussions
Use Java code to capture landmarks points
carlos_c_6
Hi guys.
I tried to make some test in relasense camera using the java language.
Below the code.
I tried to capture de landmaks but the java program return the null points.
Why?
import intel.rssdk.PXCMCaptureManager;
import intel.rssdk.PXCMFaceConfiguration;
import intel.rssdk.PXCMFaceData;
import intel.rssdk.PXCMFaceModule;
import intel.rssdk.PXCMSenseManager;
import intel.rssdk.PXCMSession;
import intel.rssdk.pxcmStatus;
public class TesteLandMark {
	public static void main(String[] args) {
		// Create session
		PXCMSession session = PXCMSession.CreateInstance();
		if (session == null) {
			System.out.print("Failed to create a session instance\n");
			System.exit(3);
		PXCMSenseManager senseMgr = session.CreateSenseManager();
		if (senseMgr == null) {
			System.out.print("Failed to create a SenseManager instance\n");
			System.exit(3);
		PXCMCaptureManager captureMgr = senseMgr.QueryCaptureManager();
		captureMgr.FilterByDeviceInfo("RealSense", null, 0);
		pxcmStatus sts = senseMgr.EnableFace(null);
		if (sts.compareTo(pxcmStatus.PXCM_STATUS_NO_ERROR) < 0) {
			throw new IllegalStateException("Failed to enable face");
		PXCMFaceModule face = senseMgr.QueryFace();
		PXCMFaceConfiguration cfg = face.CreateActiveConfiguration();
		cfg.EnableAllAlerts();
		cfg.ApplyChanges();
		cfg.close();
		sts = senseMgr.Init();
		while (senseMgr.AcquireFrame(true) == pxcmStatus.PXCM_STATUS_NO_ERROR) {
			  PXCMFaceModule face2 = senseMgr.QueryFace();
			  PXCMFaceData faceData = face2.CreateOutput();
			  faceData.Update();
			  int numFaces = faceData.QueryNumberOfDetectedFaces();
			  System.out.println("Saw: " + numFaces + " faces.");
			  for (int i = 0; i < numFaces; i++)  {
				  // Retrieve the face landmark data instance
				   PXCMFaceData.Face face1 = faceData.QueryFaceByIndex(i);
				   PXCMFaceData.LandmarksData ldata = face1.QueryLandmarks();
				   // allocate the array big enough to hold the landmark points.
				   int npoints = ldata.QueryNumPoints();
				   PXCMFaceData.LandmarkPoint[] points = new PXCMFaceData.LandmarkPoint[npoints];
				   // get the landmark data
				   ldata.QueryPoints(points);
				   for(PXCMFaceData.LandmarkPoint p: points){
					   if(p != null){
						   System.out.println("points x: " + p.image.x);
						   System.out.println("points y: " + p.image.y);
			  faceData.close();
			  senseMgr.ReleaseFrame();
Xusheng_L_Intel
Which camera are you using? Which version release SDK? Where did you get Null? Please provide us detail info so I can help you. Thanks!
carlos_c_6
Hi David
Below the information about the SDk. The camera is RealSense F200
  • Intel(R) RealSense(TM) SDK 8.0.24.6528
  • Intel(R) RealSense(TM) SDK Runtime 6.0.21.6598
  • Intel(R) RealSense(TM) Depth Camera Manager 1.4.27.41944
  • Intel(R) RealSense(TM) 3D Camera 2780
I tryed pick up the landmarks position but the code bring the points null.
                       if(p != null){
KKasu
Hi All,
I got same Issue ? Any one came up with a solution ? Please share
Cheers
