Software Archive
Read-only legacy content
17060 Discussions
Use of intrinsic function: UBOUND !
aagaard
I am trying to use the intrinsic function UBOUND to determine the size of an array, transferred as parameter to a subroutine. I am not able even to compile the code.
As far as I read the documentation, it should be possible the determine the upper bound of an assumed size array.
What am I dping wrong ????
Example:
   program bounds
   implicit none
   INTEGER(4), PARAMETER :: MXDIME=10
   INTEGER(4)  :: NXTEST,MXBOUN
   DIMENSION NXTEST(1:MXDIME)
      MXBOUN=LBOUND(NXTEST,DIM=1)
      WRITE(*,*) 'MAIN:LOWER BOUNDS:',MXBOUN
      MXBOUN=UBOUND(NXTEST,DIM=1)
      WRITE(*,*) 'MAIN:UPPER BOUNDS:',MXBOUN
      CALL XTESTS(NXTEST)
   end program bounds
    SUBROUTINE XTESTS(NYTEST)
    IMPLICIT NONE
    INTEGER(4)  :: NYTEST,MXBOUN
    DIMENSION NYTEST(*)
       MXBOUN=LBOUND(NYTEST,DIM=1)
       WRITE(*,*) 'SUB:LOWER BOUNDS:',MXBOUN
       MXBOUN=UBOUND(NYTEST,DIM=1)
       WRITE(*,*) 'SUB:UPPER BOUNDS:',MXBOUN
    END
The wording in the manual is "It can be an assumed-size array if DIM is present with a value less than the rank of ARRAY." (emphasis mine).
In your case, your array argument has rank 1, therefore there is no value of DIM that is acceptable. The idea is if you have a multi-dimensioned array, you can use UBOUND to get the bound of all but the last dimension, since only the last is permitted to have * as an upper bound.
Steve
