Software Archive
Read-only legacy content
17060 Discussions
Use of parallel port
Intel_C_Intel
I try to get control over the parallel port in order to command and control equipment connected to this port.
Using a modern computer running under Windows (both 95 and NT 4) I have significant problems with this. After reading the DVF manuals, I thought if there is a way, I have to use the Windows API, therefore, I tried that. However, maybe since I do not know anything about C programming, I failed.
This leads to my question. Is there anybody there who had already the same problem? Maybe someone could show me by an example how I could handle the parallel port? I need something which is able to send out any code, read any code and check the signal lines (i.e. busy, etc.).
Thanks in advance for any replies.
alfredodell
Use the following routines to read/write to a port
function inport(iport)
external inportb
pointer(p,inportb)
integer code(3)
data code / #0424548B, #c033128B, #0004c2EC /
p = loc(code)
inport = inportb(iport)
return
end
subroutine outport(ibyte, iport)
external outportb
pointer(p,outportb)
integer code(4)
data code / #0424548B, #548B028A, #128B0824, #0008C2EE  /
p = loc(code)
call outportb(ibyte, iport)
return
end
Each parallel part has 3 port locations:
port - write/read data 8 bits
port+1 - read status 5 bits
port+3 - write status 4 bits
where port is usually #378 or #278
If the port is bidirectional bit5 (32) of port+3 is set for read, clear for write
Eg
iport=#387
call outport(0, iport+2) !set data port to write & write 0 to output status
call outport(24, iport) !write 24 to data port
call outport(13+32, iport+2) !set data port to read and write 13 to output status
i = inport(port+1) !read status port
Parallel port pins are as follows:
2,3,4,5,6,7,8,9 - Bits 0 to 7 of data port
1,14,16,17 - Bits 0 to 3 of output status port .XOR.11
13,13,12,10,11 Bits 3 t0 7 of input status port .XOR.128
