Software Archive
Read-only legacy content
17060 Discussions
Using Intel RealSense R200 with Intel Edison
Christopher_P_
I want to use the Intel RealSense R200 directly with the Intel Edison. Does anyone know if this is possible yet? If so, how would i go about connecting the two?
A more general question if the Intel Edison is hopeless. Is there any flight controller that I can connect an Intel RealSense R200 camera with?
Thanks in advance.
samontab
Valued Contributor II
mmm, maybe the Odroid XU4 may be able to run it?, at least it has USB3, and it is small and lightweight.
Also, there is the minnowboard max board, which is basically a full 64 bit computer in a tiny package, slightly larger than the odroid. It also has USB3.0
Any of those two would be my choices...
Let us know if any of them actually work!
Christopher_P_
I will definitely look into both of those. I want to use the Intel Edison to run it because I already have on but I guess that's not possible yet.
I'll keep you guys updated!
