Software Archive
Read-only legacy content
17060 Discussions
Using LEA instructions
roysykes
In his useful paper "Assembly Language Tips & Tricks for the Intel Pentium 4 Processor", Khang Nguyen suggested the following:
  • Using lea Instructions:
mov edx,ecx
sal edx,3
Faster:
lea edx, [ecx + ecx]
add edx, edx
add edx, edx
While I suppose
XOR EDX,EDX
SHRD EDX,ECX,29
has the same issues as first fragment, would not
LEA EDX,[ECX*8] (seven bytes)
or, if you have another spare zero register, say EBX, a denser encoding would be
LEA EDX,[EBX+ECX*8] (three bytes)
Would these not be faster, with the further advantage of changing no flags? /Roy Sykes
Intel_Software_Netw1
We will forward your question to the author and let you know what response we receive.
For those following along, here is a link to the article.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Message Edited by intel.software.network.support on 12-09-2005 10:48 AM
The author responded as follows:
The reason the combination of lea and add is faster because it gets away from the shifting instruction.
Lets look at the statement:
This operation involves multiplication (shifting) which is known to be slowed.
The following statement is even worse:
This operation also involves multiplication and another operation to set the register EBX to zero.
Hope this helps!
Lexi S.
Contact us
Message Edited by intel.software.network.support on 12-02-2005 08:50 PM
jim_dempsey
This is for Lexi
The "LEA EDX,[ECX*8]" instructionalthough appears text wise to involve multiplication (*) it doesnot. Also, this does not involve a shift operation. If either were true then your processor wizards would need to go back to school. Simple shift-like operations for *1, *2, *4, *8 are so common that are hardwired into the archetecture. All permutations arealways presenta multiplexer selects the desired result.
Jim Dempsey
