Software Archive
Read-only legacy content
17060 Discussions
Using admob to add ads- basic question
Sara_I_
I am following steps as on https://udinra.com/blog/admob-ads-intel-xdk-mobile-app
I have done up to step 6.
I am unsure where the code in this step should be posted.  Does it go on the intex.html page?
I'm totally new to this stuff, any help greatly appreciated,
Sara.
Sara_I_
bump.
PaulF_IntelCorp
Sara_I_
bump.
Amrita_C_Intel
Yes! It will go inside index.html file. And for future you can always refer to existing samples.
Anusha_M_Intel1
You can either place it within script tags in index.html or specify it in .js files and reference them in index.html. Eg:
<script type='text/javascript' src="js/admob.js"></script>
There is a sample illustrating Admob use that ships with the XDK.
Start new project -> Samples and Demos -> General -> HTML5+Cordova -> Hello Admob.
You can refer to that code for better understanding.
Sara_I_
Thanks for the reply. and where it says 'your code here' on https://udinra.com/blog/admob-ads-intel-xdk-mobile-app step 6,
what code is that referring to?
E.g, say if I insert a grid , would the code corresponding to this go here or elsewhere?
Many thanks.
Amrita_C_Intel
It depends when you wish to trigger particular event before or after or at the time of initialization. It is totally your choice. To experiment you can include piece of code at different places to watch the emulation behavior.
Anusha_M_Intel1
Typically the onDeviceReady() event is fired when Cordova is fully loaded. It signals that Cordova's device APIs have loaded and are ready to access and now you can safely make call to Cordova APIs.
You can ready more about it here: https://cordova.apache.org/docs/en/4.0.0/cordova_events_events.md.html
