Hi all,
I am using the offload programming model for my project. What I have is a global pointer that I use to allocate memory on the MIC. After doing some more computation on the host I then try to copy the results from host memory to the memory in the MIC using in() for host structure and nocopy() for the global pointer. The documentation and a few of the forum posts say that it should work however in my case it results in a segfault.
What I read:
https://software.intel.com/en-us/articles/effective-use-of-the-intel-compilers-offload-features
The code is something like this:
//This is global
__attribute__((target(mic:0))) wildstruct* foo;
#pragma offload target(mic:0) nocopy(foo) {
foo = malloc(sizeof(foo)); //foo is then initialized later on in this offload region.
In another file:
#pragma offload target(mic:0) in(anotherFoo[0:LENGTH]) nocopy(foo) {
memset(foo,anotherFoo,sizeof(foo)); //segfaults here. foo is NULL which I believe should not be the case according to the documentation.
Thanks!
