Software Archive
Read-only legacy content
17060 Discussions
VB and DF mixed programming
yenbm
Just got my DF6.5 today and installed it. But I need to write a VB program with DF functions/subs. I understand that DF needs to be build as DLL to allow VB to call it. Is there anyone can provide samples for this kind of apps?
Thanks!
There's a sample under the MIXLANG folder in the provided samples - INFODFSAMPLES on your CD if you didn't install them. Also, our web site has an annotated sample.
Steve
durisinm
You should also read chapter 18 of the Visual Fortran Programmer's Guide. It contains lots of good information about mixed language programming.
Mike Durisin
canaimasoft
Check the f90VB User Manual:
http://www.canaimasoft.com/f90VB/OnlineManuals/UserManual/default.htm
The manual has two chapters that deal with this topic specifically. Much (if not all) of the information there should be usable, even if you don?t have our product. There are also specific examples for CVF.
Another link that might be useful is our tutorial on creating VB GUI for Fortran:
http://www.canaimasoft.com/f90VB/OnlineManuals/GUITutorial/default.htm
Hope this helps.
Marco A. Garcia
Canaima Software
P.O. Box 13162
La Jolla, CA. 92039
U.S.A.
e-mail:[email protected]
Tel/Fax: (619) 233-6831
Developers of f90SQL the Database Connectivity Solution for Fortran, and f90VB the Library for Fortran-OLE Automation and Fortran-VB Programming
