Software Archive
Read-only legacy content
17060 Discussions
VM-entry failure due to invalid guest state.
Sergey_Pisarev
Hello !
I am developing driver that converts currently running OS to run under hypervisor(something like SimpleVisor). After vmlaunch cpu jumps to vm-exit dispatcher with exit reason 0x80000021 (VM-entry failure due to invalid guest state). I have checked everything in 26.3.1 Checks on the Guest State Area and fixed all the errors I have found. I am still getting this error. Below caps of my cpu and values in guest area. Maybe someone can glance over it and notice something invalid.
IA32_VMX_BASIC      (0x480) hex:0x00da0400`0000000f bin:00000000 11011010 00000100 00000000 00000000 00000000 00000000 00001111
IA32_VMX_CR0_FIXED0 (0x486)  hex:0x80000021 bin:10000000 00000000 00000000 00100001
IA32_VMX_CR0_FIXED1 (0x487)  hex:0xffffffff bin:11111111 11111111 11111111 11111111
guest_cr0          (0x6800)  hex:0x80050031 bin:10000000 00000101 00000000 00110001
IA32_VMX_CR4_FIXED0 (0x488) hex:0x2000  bin:00000000 00000000 00100000 00000000
IA32_VMX_CR4_FIXED1 (0x489) hex:0x227ff bin:00000000 00000010 00100111 11111111
guest_cr4          (0x6804) hex:0x26f8  bin:00000000 00000000 00100110 11111000
ia32_vmx_true_pinbased_ctls(0x48D)      hex:0x0000007f`00000016 bin:00000000 00000000 00000000 01111111 00000000 00000000 00000000 00010110
pin_based_vm_execution_controls(0x4000) hex:0x16                bin:00000000 00000000 00000000 00010110
ia32_vmx_true_procbased_ctls(0x48e)                   hex:0xfff9fffe`04006172 bin:11111111 11111001 11111111 11111110 00000100 00000000 01100001 01110010
primary_processor_based_vm_execution_controls(0x4002) hex:0x94006172          bin:10010100 00000000 01100001 01110010
ia32_vmx_procbased_ctls2(0x48b)                         hex:0x000000ff`00000000 bin:00000000 00000000 00000000 11111111 00000000 00000000 00000000 00000000
secondary_processor_based_vm_execution_controls(0x401e) hex:0xaa                bin:00000000 00000000 00000000 10101010
ia32_vmx_true_exit_ctls(0x48f) hex:0x007fffff`00036dfb bin:00000000 01111111 11111111 11111111 00000000 00000011 01101101 11111011
vm_exit_controls(0x400c)       hex:0x3efff             bin:00000000 00000011 11101111 11111111
ia32_vmx_true_entry_ctls(0x490) hex:0x0000ffff`000011fb bin:00000000 00000000 11111111 11111111 00000000 00000000 00010001 11111011
vm_entry_controls(0x4012)       hex:0x13ff              bin:00000000 00000000 00010011 11111111
guest_cr3(0x6802) hex:0x1aa000
guest_dr7    (0x681a) hex:0x400
guest_rflags (0x6820) hex:0x286 bin:00000000 00000000 00000000 00000000 00000000 00000000 00000010 10000110
guest_rsp(0x681c) hex:ffff8202cf325858
guest_rip(0x681e) hex:fffff80116c61058
guest_cs_selector(0x802)       hex:0x10 bin:00000000 00010000
guest_cs_base(0x6808)          hex:0
guest_cs_limit(0x4802)         hex:0
guest_cs_access_rights(0x4816) hex:0x209b bin:00000000 00000000 00100000 10011011
guest_es_selector(0x800)       hex:000000000000002b bin:00000000 00101011
guest_es_base(0x6806)          hex:0
guest_es_limit(0x4800)         hex:00000000ffffffff
guest_es_access_rights(0x4814) hex:0xcff3 bin:00000000 00000000 11001111 11110011
guest_ss_selector(0x804)       hex:0x18 bin:00000000 00011000
guest_ss_base(0x680a)          hex:0
guest_ss_limit(0x4804)         hex:0
guest_ss_access_rights(0x4818) hex:0x4093 bin:00000000 00000000 01000000 10010011
guest_ds_selector(0x806)       hex:0x2b bin:00000000 00101011
guest_ds_base(0x680c)          hex:0
guest_ds_limit(0x4806)         hex:0xffffffff
guest_ds_access_rights(0x481a) hex:0xcff3 bin:00000000 00000000 11001111 11110011
guest_fs_selector(0x808)       hex:0x53 bin:00000000 00000000 00000000 01010011
guest_fs_base(0x680e)          hex:0
guest_fs_limit(0x4808)         hex:0x3c00
guest_fs_access_rights(0x481c) hex:0x40f3 bin:00000000 00000000 01000000 11110011
guest_gs_selector(0x80a)       hex:0x2b bin:00000000 00101011
guest_gs_base(0x6810)          hex:fffff8024b822000
guest_gs_limit(0x480a)         hex:0xffffffff
guest_gs_access_rights(0x481e) hex:0xcff3 bin:00000000 00000000 11001111 11110011
guest_gdtr_base(0x6816)  hex:fffff8024ea53fb0
guest_gdtr_limit(0x4810) hex:0x57
guest_ldtr_selector(0x80c)       hex:0
guest_ldtr_limit(0x480c)         hex:0
guest_ldtr_base(0x6812)          hex:0
guest_ldtr_access_rights(0x4820) hex:0x10000 bin:00000000 00000001 00000000 00000000
guest_tr_selector(0x80e)       hex:0x40 bin:00000000 01000000
guest_tr_limit(0x480e)         hex:0x67
guest_tr_base(0x6814)          hex:fffff8024ea52000
guest_tr_access_rights(0x4822) hex:0x8b bin:00000000 00000000 00000000 10001011
guest_idtr_limit(0x4812) hex:0xfff
guest_idtr_base(0x6818)  hex:fffff8024ea51000
guest_ia32_debugctl(0x2802)     hex:0
guest_ia32_sysenter_cs(0x482a)  hex:0
guest_ia32_sysenter_esp(0x6824) hex:0
guest_ia32_sysenter_eip(0x6826) hex:0
exit_reason(0x4402) hex:0x80000021 bin:10000000 00000000 00000000 00100001
exit_qualification(0x6400) hex:0
Quoc-Thai_L_Intel
got some feedbacks from my peers:
The exit reason shows that there’s something wrong when checking guest area, just like the original post. I personally did another check again that (SDM 26.3.1) but I failed to see anything wrong.
But the log of guest states provided in the email didn’t contain all guest area info, for example, it didn’t have non-register state. So I think it would be good to check that area too.
Another thing is it seems both VMEXIT for external interrupt and NMI interrupt are disabled. This is probably not the typical case IMHO but maybe it is a very thin hypervisor only for special purpose."
-Thai
Sergey_Pisarev
Thank you ! The reason was a misconfigured access rights for some selectors (S flag to be precise)
Quoc-Thai_L_Intel
Thanks for comments back which would be helpful for others having the similar issue...:)
-Thai
