Software Archive
Read-only legacy content
17060 Discussions
VS2008 Problem Changing Back to MS Compiler
Eckhardt__Stephen
I switched a project over to use Parallel Composer update 5 in VS2008. Unfortunately, my customer doesn't have Parallel Studio, so I have to change back to the MS compiler before saving the solution file to the repository. When I make the change and build, I get messages that say "cannot open file 'libmmd.lib' What do I need to change to get back to the Microsoft libraries?
KitturGanesh
I need to redo the previous post. Since libmmd is built into the .obj files, you'll just need to just "rebuild" the projects convered back to MS which should work fine else it's a bug...
Can you please clean and rebuild and see if it resolves?
-regards,
Kittur
