Software Archive
Read-only legacy content
VT enable
jobin444
i want to know that intel G31PR m/b will support intel VT Technology?.If not which desktop series M/B will support. I have core2 duo 2.8ghz with dg3PR m/b.This processor i can use with VT enable M/B?.Vt enabled motherboard available in india? Please give a solution
levicki
Valued Contributor I
Quoting - jobin444
Intel G31PR mainboard manual says that there is an option to enable/disable VT Technology in BIOS under Security menu. However, whether you will have VT or not depends also on a processor you chose. To check whether any particular CPU supports VT use http://processorfinder.intel.com/.
