Software Archive
Read-only legacy content
17060 Discussions
Version 1912 ionic controls not loading
Nick_F_2
New Contributor III
Version 1912 doesn't appear to know which UI Framework is loaded.
When editing the UI framework from App Frame or JQuery to ionic the controls do not load.
The only way I can get the ionic controls is to start a new project.
Chris_P_Intel
What does that mean? Are you changing the framework from the projects pane? Or coding the document by hand two switch to use the Ionic framework?
Nick_F_2
New Contributor III
I'm clicking on the Edit UI Framework option under Project Tab. I have attached a screen grab movie of whats happening.
Amrita_C_Intel
I recreated your issue and cannot see this problem with either of them i.e. Jquery and ionic. I would recommend you to update the XDK version to1995. Let me know if you have any further question.
