Software Archive
Read-only legacy content
17060 Discussions
Visual Studio 2008 Build & Run hangs after installing Intel C/C++ Studio
driekus77
Dear maddam/sir,
My Visual Studio 2008 versions hangs when clicking Build or Run. This was working oke before installing Intel C/C++ Studio 32bits.
My version info is:
- Microsoft Visual Studio 2008 SP1
- Intel C/C++ Studio 2011 Update 3 (c_studio_xe_2011_sp1_update3_ia32_setup)
Intel XE Inspector standalone look to be working fine.
Hope to hear from you.
Kind regards,
Henry Roeland
Bernard
Valued Contributor I
Is this global i.e system-wide hang or only process related.
gaston-hillar
Have you checked the tried deactivating all the add-ins you have for Visual Studio 2008 SP1 (if any).
I had a problem a long time ago with a different Intel C/C++ version and it was caused by other add-ins I had installed to Visual Studio 2008 SP1. :)
Hope it helps.
Cheers,
Gaston
Maycon_Oliveira
Check the properties of the project if you are using build events.
Maycon_Oliveira
...this problem happens when we use cryptograph to create strong named assemble.
Sometimes when we use FXCopy or StyleCopy in big application. Or when have lot of class in NUnit and you execute before each build.
Maycon_Oliveira
Check if your project are correctly configured with 32 or 64 bit.
driekus77
Thanks everybody for advise and tips!
Stuppid me was the problem:
"I was working at home with a slow VPN connection in a VS 2008 project that had references to a disk over the VPN line".
When I copied the referenced libraries localy everything worked.
Sorry for the fus.
Kind regards,
Henry
