Software Archive
Read-only legacy content
17060 Discussions
WEINRE Tag code has a bug...
Robert_T_1
Hello, when asked to add the WEINRE tag to my XDK project, it produces an error.
The code that gets embedded has a bug - it starts with broken code.
http://debug-software.intel.com/target/target-script-min.js
The first three lines read as follows
odeId);
return;
I could be misunderstanding, but it sure looks like a bug in the code to me.
any advice would be appreciated.
Amrita_C_Intel
As a workaround, you can run weinre directly on your own system, without help from the XDK. See the very bottom of this page for some links that will show you how to do that (requires installing node.js on your system) > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overv...
Rakshith_K_Intel
Thanks for reporting, we just fixed the issue.
