Software Archive
Read-only legacy content
17060 Discussions
WIndows UAP Build Fails
Kevin_L_3
I get this warning when I try the Windows UAP 10 build
"Warning: Plugin Application Events appears to be missing the windows platform support required for this build target. The API provided by this plugin may not work on the windows platform."
But can't find what is the appropriate plugin to use - as the ones on the pre-canned list don't work. Any ideas?
Amrita_C_Intel
which plugin are you trying to use?
After warning are you able to build it?
Kevin_L_3
As best as I can tell I removed the plugin dependent on events - this being local notifications. The other plugins I use don't have this dependency. The Windows 8 and 8.1 build without issues. I don't have the full list of plugins and versions to hand but will post in a day or two.
PaulF_IntelCorp
Kevin -- the way you can tell if a plugin is supported or not on the Windows platform is by inspecting the plugin.xml file that is present in every plugin. If that plugin includes a section like this (taken from the device plugin):
    <platform name="windows">
        <js-module src="src/windows/DeviceProxy.js" name="DeviceProxy">
            <merges target="" />
        </js-module>
    </platform>
The parts between the <platform> tags are a function of the specific plugin. What is important is the existence of that <platform name="windows"> section. If present, the plugin supports Windows. If not, you will get the warning, because it has no support for the "windows" target. If there is a "windows8" target that may still work.
