Software Archive
Read-only legacy content
17060 Discussions
WebApp build is corrupting images
Ad
New Contributor III
If we build a WebApp, all the included JPG and PNG files are corrupted.
In previous WebApp builds, with the same XDK version, everything went fine.
Can someone check this and does anyone have the same problem?
P.S. Our quick and dirty solution is to copy manually the files to our server , in stead of building a WebApp.
PaulF_IntelCorp
Ad, can you provide an example web app zip and the corresponding project ZIP (zip the ENTIRE project directory) and attach it to this thread so we can see what is going on?
Ad
New Contributor III
I have sent you a PM with the corresponding project ZIP.
PaulF_IntelCorp
Thanks for the project. It also appears that your font files are being corrupted. I've notified engineering of this problem.
PaulF_IntelCorp
The problem has been fixed.
Ad
New Contributor III
Just tested it and works like before!
THANKS for the quick fix!
