Software Archive
Read-only legacy content
17060 Discussions
Webservices API Explorer Sandbox
Andrew_D_6
I'm trying to use our own .NET API to securely log in to our website through an APP that we are currently developing in XDK but when I use the API Explorer Sandbox there are so many options I don't know which ones to select. Please could someone take a look and advise?
Here is our API: http://index.leaveplanner.com/webservice/PublicAPI.svc?singleWsdl
To login it requires a username and password. When working it should parse back a "0" for "username and password incorrect".
Any help with this would be greatly appreciate.
Andrew
Rakshith_K_Intel
 API Explorer Sandbox in Webservices can be used for making a GET or POST requests with URL params only, it does not really support any basic auth for passing username and password.
If you have APIs that returns data response in json/xmp then you can use  API Explorer Sandbox to create bindings for it and use in App Designer to create data bindings.
Andrew_D_6
Hi Rakshith,
Thanks for getting back to me. The data response is in JSON and the XDK brings up a load of tick boxes to create a data binding, but I don't know how to get it working. There are so many responses that I don't know which to select so that I can hook the service up to the login button and get in to the app? Here are the results when using GET:
<div>
  •  Object
    • "definitions": Object
      • __cnt : 24
        "types": Object
        • __cnt : 3
          "schema": Array[2]
          • Object
            • __cnt : 6
              "element": Array[2]
              • Object
                • __cnt : 3
                  "complexType": Object
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 3
                      "element": Array[2]
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                      "element_asArray": Array[2]
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                    "sequence_asArray": Array[1]
                    • Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                  "complexType_asArray": Array[1]
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 2
                      "element": Object
                      • __cnt : 4,
                      "element_asArray": Array[1]
                      • Object
                        • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
              • Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 3
                      "element": Array[2]
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                    • Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 2
                      "element": Object
                      • __cnt : 4,
                      • Object
                        • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
            Object
            • __cnt : 33
              "element": Array[21]
              • Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
              "element_asArray": Array[21]
              • Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
              "simpleType": Array[3]
              • Object
                • __cnt : 3
                  "restriction": Object
                  • __cnt : 2,
                  "restriction_asArray": Array[1]
                  • Object
                    • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 5
                    "pattern": Object
                    • __cnt : 2,
                    "pattern_asArray": Array[1]
                    • Object
                      • __cnt : 2,
                    "minInclusive": Object
                    • __cnt : 2,
                    "minInclusive_asArray": Array[1]
                    • Object
                      • __cnt : 2,
                    "maxInclusive": Object
                    • __cnt : 2,
                    "maxInclusive_asArray": Array[1]
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 3
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
              "simpleType_asArray": Array[3]
              • Object
                • __cnt : 3
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 5
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 3
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
              "attribute": Array[3]
              • Object
                • __cnt : 3,
                Object
                • __cnt : 3,
                Object
                • __cnt : 3,
              "attribute_asArray": Array[3]
              • Object
                • __cnt : 3,
                Object
                • __cnt : 3,
                Object
                • __cnt : 3,
          "schema_asArray": Array[2]
          • Object
            • __cnt : 6
              "element": Array[2]
              • Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 3
                      "element": Array[2]
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                    • Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 2
                      "element": Object
                      • __cnt : 4,
                      • Object
                        • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
              • Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 3
                      "element": Array[2]
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                      • Object
                        • __cnt : 5,
                        Object
                        • __cnt : 5,
                    • Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                Object
                • __cnt : 3
                  • __cnt : 2
                    "sequence": Object
                    • __cnt : 2
                      "element": Object
                      • __cnt : 4,
                      • Object
                        • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                  • Object
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
            Object
            • __cnt : 33
              • Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
              • Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
                Object
                • __cnt : 4,
              • Object
                • __cnt : 3
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 5
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 3
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
              • Object
                • __cnt : 3
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 5
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                Object
                • __cnt : 3
                  • __cnt : 3
                    "pattern": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  • Object
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
              • Object
                • __cnt : 3,
                Object
                • __cnt : 3,
                Object
                • __cnt : 3,
              • Object
                • __cnt : 3,
                Object
                • __cnt : 3,
                Object
                • __cnt : 3,
        "types_asArray": Array[1]
        • Object
          • __cnt : 3
            "schema": Array[2]
            • Object
              • __cnt : 6
                "element": Array[2]
                • Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                        • Object
                          • __cnt : 3
                            "element": Array[2]
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                  Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                        • Object
                          • __cnt : 2
                            "element": Object
                            • __cnt : 4,
                            • Object
                              • __cnt : 4,
                • Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                        • Object
                          • __cnt : 3
                            "element": Array[2]
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                  Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                        • Object
                          • __cnt : 2
                            "element": Object
                            • __cnt : 4,
                            • Object
                              • __cnt : 4,
              Object
              • __cnt : 33
                • Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                • Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                • Object
                  • __cnt : 3
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 5
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 3
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                • Object
                  • __cnt : 3
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 5
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 3
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                • Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                • Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
            • Object
              • __cnt : 6
                "element": Array[2]
                • Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                        • Object
                          • __cnt : 3
                            "element": Array[2]
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                  Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                        • Object
                          • __cnt : 2
                            "element": Object
                            • __cnt : 4,
                            • Object
                              • __cnt : 4,
                • Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 3
                        "element": Array[2]
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                        • Object
                          • __cnt : 5,
                          Object
                          • __cnt : 5,
                      • Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 3
                          "element": Array[2]
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                          • Object
                            • __cnt : 5,
                            Object
                            • __cnt : 5,
                        • Object
                          • __cnt : 3
                            "element": Array[2]
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                            • Object
                              • __cnt : 5,
                              Object
                              • __cnt : 5,
                  Object
                  • __cnt : 3
                    • __cnt : 2
                      "sequence": Object
                      • __cnt : 2
                        "element": Object
                        • __cnt : 4,
                        • Object
                          • __cnt : 4,
                      • Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                    • Object
                      • __cnt : 2
                        "sequence": Object
                        • __cnt : 2
                          "element": Object
                          • __cnt : 4,
                          • Object
                            • __cnt : 4,
                        • Object
                          • __cnt : 2
                            "element": Object
                            • __cnt : 4,
                            • Object
                              • __cnt : 4,
              Object
              • __cnt : 33
                • Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                • Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                  Object
                  • __cnt : 4,
                • Object
                  • __cnt : 3
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 5
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 3
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                • Object
                  • __cnt : 3
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 5
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 5
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                  Object
                  • __cnt : 3
                    • __cnt : 3
                      "pattern": Object
                      • __cnt : 2,
                      • Object
                        • __cnt : 2,
                    • Object
                      • __cnt : 3
                        "pattern": Object
                        • __cnt : 2,
                        • Object
                          • __cnt : 2,
                • Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                • Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
                  Object
                  • __cnt : 3,
        "message": Array[2]
        • Object
          • __cnt : 3
            "part": Object
            • __cnt : 3,
            "part_asArray": Array[1]
            • Object
              • __cnt : 3,
          Object
          • __cnt : 3
            "part": Object
            • __cnt : 3,
            • Object
              • __cnt : 3,
        "message_asArray": Array[2]
        • Object
          • __cnt : 3
            "part": Object
            • __cnt : 3,
            • Object
              • __cnt : 3,
          Object
          • __cnt : 3
            "part": Object
            • __cnt : 3,
            • Object
              • __cnt : 3,
        "portType": Object
        • __cnt : 3
          "operation": Object
          • __cnt : 4
            "input": Object
            • __cnt : 3,
            "input_asArray": Array[1]
            • Object
              • __cnt : 3,
            "output": Object
            • __cnt : 3,
            "output_asArray": Array[1]
            • Object
              • __cnt : 3,
          "operation_asArray": Array[1]
          • Object
            • __cnt : 4
              "input": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
              "output": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
        "portType_asArray": Array[1]
        • Object
          • __cnt : 3
            "operation": Object
            • __cnt : 4
              "input": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
              "output": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
            • Object
              • __cnt : 4
                "input": Object
                • __cnt : 3,
                • Object
                  • __cnt : 3,
                "output": Object
                • __cnt : 3,
                • Object
                  • __cnt : 3,
        "binding": Object
        • __cnt : 5
          "binding": Object
          • __cnt : 2,
          "binding_asArray": Array[1]
          • Object
            • __cnt : 2,
          "operation": Object
          • __cnt : 5
            "operation": Object
            • __cnt : 3,
            • Object
              • __cnt : 3,
            "input": Object
            • __cnt : 2
              "body": Object
              • __cnt : 2,
              "body_asArray": Array[1]
              • Object
                • __cnt : 2,
            • Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
            "output": Object
            • __cnt : 2
              "body": Object
              • __cnt : 2,
              • Object
                • __cnt : 2,
            • Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
          • Object
            • __cnt : 5
              "operation": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
              "input": Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
              • Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
              "output": Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
              • Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
        • Object
          • __cnt : 5
            "binding": Object
            • __cnt : 2,
            • Object
              • __cnt : 2,
            "operation": Object
            • __cnt : 5
              "operation": Object
              • __cnt : 3,
              • Object
                • __cnt : 3,
              "input": Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
              • Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
              "output": Object
              • __cnt : 2
                "body": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
              • Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
            • Object
              • __cnt : 5
                "operation": Object
                • __cnt : 3,
                • Object
                  • __cnt : 3,
                "input": Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
                • Object
                  • __cnt : 2
                    "body": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
                "output": Object
                • __cnt : 2
                  "body": Object
                  • __cnt : 2,
                  • Object
                    • __cnt : 2,
                • Object
                  • __cnt : 2
                    "body": Object
                    • __cnt : 2,
                    • Object
                      • __cnt : 2,
        "service": Object
        • __cnt : 3
          "port": Object
          • __cnt : 4
            "address": Object
            • __cnt : 2,
            "address_asArray": Array[1]
            • Object
              • __cnt : 2,
          "port_asArray": Array[1]
          • Object
            • __cnt : 4
              "address": Object
              • __cnt : 2,
              • Object
                • __cnt : 2,
        "service_asArray": Array[1]
        • Object
          • __cnt : 3
            "port": Object
            • __cnt : 4
              "address": Object
              • __cnt : 2,
              • Object
                • __cnt : 2,
            • Object
              • __cnt : 4
                "address": Object
                • __cnt : 2,
                • Object
                  • __cnt : 2,
</div>
If you can shed any light on this, it would be great.
Andrew
Rakshith_K_Intel
Here are video links showing how to use web servies:
https://software.intel.com/en-us/videos/using-services-datafeed-in-app-designer
more details here: https://software.intel.com/en-us/xdk/docs/using-web-services
