Software Archive
Read-only legacy content
Which HOST ID
mike_y_
We have just purchased Parallel Studio XE Cluster NmdU and plan to perform an offline installation. Search through the forum with many similar issue but not sure about the exact answer
We will be using a precompile version hence the we do require a license file to activate it. However we have multiple NIC on the machine. Most of the eth including eth0 is running on local private network but eth1 is connected to the public (net). Should we use eth0 or eth1 as host id ?
Mike
James_T_Intel
Please use the first host ID reported for the system.  This should correspond to eth0.
