Hi All,
I am a rookie in the Intel Developer Zone, but I was fortunate to have early access to Intel Xeon Phi coprocessors for some time. Now that Intel has lifted the Xeon Phi coprocessor's veil, I am happy to share my user experience and demonstrate some examples.
I have written a white paper investigating a toy model, the N-body simulation, on an Intel Xeon Phi coprocessor. The PDF file can be downloaded here: http://research.colfaxinternational.com/file.axd?file=2013%2f1%2fColfax_Nbody_Xeon_Phi.pdf . The paper contains code samples, assembly listings and performance results, and discusses some programming practices for the efficient utilization of the coprocessor. Most importantly, it demonstrates that a single C/C++ code can efficiently run on Xeon processors and Xeon Phi coprocessors. Mind that the performance results are obtained on a pre-production sample, and the specifications and performance of the final product may be different.
If this paper has some utility to fellow developers and scientists, I will be thrilled. I am also looking forward to discussions on this forum and learning about the experience of other people with Xeon Phi programming.
Cheers,
Andrey.
Andrey,
Thank you for contributing to the community.
Taylor
Hi Andrey
May I get your source code run on Xeon processors and Xeon Phi coprocessors.
zhu.j
@zhu.j
The part of the source code is in N-body simulation white paper.
@Andrey Vladimirov
Thank you for publishing your white paper about the N-body simulation.It helped me a lot to understand how to implement N-body simulation.
The part of the code which is missing are calls to particles initializers.
thanks
thanks
Thank you!
I managed to add Windows multithreading now I am trying to properly synchronize the threads.I run it on Haswell CPU.
Hmm, I thought that we included a complete code listing in the paper. The particle initialization step uses a random number generator for MKL. It is not a very physically meaningful setup, just some numbers to crunch.
In any case, here is a code that can be run (sorry if spacing is off):
[cpp]
#include <math.h>
#include <mkl_vsl.h>
#include <omp.h>
#include <stdio.h>
struct ParticleSystemType {
float *x, *y, *z, *vx, *vy, *vz;
int main(const int argc, const char** argv) {
const int nParticles = 30000, nSteps = 10; // Simulation parameters
const float dt = 0.01f; // Particle propagation time step
ParticleSystemType p; // Particle system stored as a structure of arrays
float *buf = (float*) malloc(6*nParticles*sizeof(float)); // Malloc all data
p.x = buf+0*nParticles; p.y = buf+1*nParticles; p.z = buf+2*nParticles;
p.vx = buf+3*nParticles; p.vy = buf+4*nParticles; p.vz = buf+5*nParticles;
// Initialize particles
VSLStreamStatePtr rnStream; vslNewStream( &rnStream, VSL_BRNG_MT19937, 1 );
vsRngUniform(VSL_RNG_METHOD_UNIFORM_STD, rnStream, 6*nParticles, buf, -1.0f, 1.0f);
// Propagate particles
printf("Propagating particles using %d threads...\n", omp_get_max_threads());
double rate = 0.0, dRate = 0.0; // Benchmarking data
const int skipSteps = 1; // Skip first iteration is warm-up on Xeon Phi coprocessor
for (int step = 1; step <= nSteps; step++) {
const double tStart = omp_get_wtime(); // Start timing
#pragma omp parallel for schedule(dynamic)
for (int i = 0; i < nParticles; i++) { // Parallel loop over particles that experience force
float Fx = 0.0f; float Fy = 0.0f; float Fz = 0.0f; // Components of force on particle i
for (int j = 0; j < nParticles; j++) { // Vectorized loop over particles that exert force
if (j != i) {
// Newton's law of universal gravity calculation.
const float dx = p.x
const float dy = p.y
const float dz = p.z
const float drSquared = dx*dx + dy*dy + dz*dz;
const float drPowerN32 = 1.0f/(drSquared*sqrtf(drSquared));
// Reduction to calculate the net force
Fx += dx * drPowerN32; Fy += dy * drPowerN32; Fz += dz * drPowerN32;
// Move particles in response to the gravitational force
p.vx += dt*Fx; p.vy += dt*Fy; p.vz += dt*Fz;
for (int i = 0; i < nParticles; i++) { // Not much work, serial loop
p.x += p.vx*dt; p.y += p.vy*dt; p.z += p.vz*dt;
const double tEnd = omp_get_wtime(); // End timing
if (step > skipSteps) // Collect statistics
{ rate += 1.0/(tEnd - tStart); dRate += 1.0/((tEnd - tStart)*(tEnd-tStart)); }
printf("Step %d: %.3f seconds\n", step, (tEnd-tStart));
rate/=(double)(nSteps-skipSteps); dRate=sqrt(dRate/(double)(nSteps-skipSteps)-rate*rate);
printf("Average rate for iterations %d through %d: %.3f +- %.3f steps per second.\n",
skipSteps+1, nSteps, rate, dRate);
free(buf);
[/cpp]
The compilation commands on Linux are:
[bash]
icpc -xhost -O3 -openmp -mkl -fimf-domain-exclusion=8 -o nbody nbody.c
icpc -O3 -openmp -mkl -fimf-domain-exclusion=8 -o nbody-mic nbody.c -mmic
[/bash]
The flag "-fimf-domain-exclusion=8" disables denormal number handling in math functions.
Hi!
For information w
ith version 14 of Intel compiler
the -fimf-domain-exclusion=8 option is no longer improving the code speed.
Thanks for the interesting comments on the code optimization.
