Software Archive
Read-only legacy content
17060 Discussions
Windows 10/ streams works, samples not
Radek_V_
I am trying SDK samples on Win 10 (latest build)
Installation was without problems, I can see streams from Camera , 3D scanner in Common Samples working.
But almost everything from F200 Samples doesn't work and crash. For example, in Blob Viewer I can see messages about Module failed to load or something about Failed to pair blob module with I/O status during crash.
Can somebody advice ? Is it possible as result of Core i5 M540@2.53Ghz which is not 4th generation of Core ?
Xusheng_L_Intel
It should support 5th Intel CPU. I will reproduce in my machine and keep you post. At the mean time, could you run the SDK_INFO in advanced mode and send the result to me? Thanks!
Radek_V_
Well, with "is not 4th" I meant that it is lower version than 4 :-D
But don't worry, I connected camera to big PC with i7 4770 and it works without problems.
