Software Archive
Read-only legacy content
Wrong order of MPSS service in RHEL7: no NFS from host on boot
Andrey_Vladimirov
New Contributor III
By default, in MPSS 3.4 and RHEL 7, the service mpss.service in multi-user.target starts before nfs.target. As a consequence, any NFS mounts from the host in mic0:/etc/fstab are not mounted after system reboot. The solution to this is to add an "After" parameter to /etc/systemd/system/mpss.service like this:
[Unit]
Description=Intel(R) MPSS control service
After=nfs.target
Perhaps MPSS developers can incorporate this into the next MPSS release?
TaylorIoTKidd
Andrey,
Thanks for the solution. I'll forward the issue to the MPSS developers.
Taylor
TaylorIoTKidd
Hi Andrey,
Filed with reference #5161860. Thanks for the info.
Taylor
Andrey_Vladimirov
New Contributor III
Thank you, Taylor!
TaylorIoTKidd
Andrey,
The next release of MPSS will have a fix for the bug you reported.
Thanks!
Taylor
TaylorIoTKidd
Andrey,
The issue is fixed and validated.
If you wish to check, the team here will appreciate it.
If you are satisfied as is, thanks for letting us know.
Taylor
