Software Archive
Read-only legacy content
17061 讨论
XDK 1912 Start New IONIC Project but failed
Mark_Z_1
初学者
942 次查看
I created a new Ionic project, but after done, there is no Ionic framework JS files in it. I run the Test, it only show a small square XDK logo.
Why? Is this a bug? Previous version does not have this problem. It show Ionic header when Test new project.
0 项奖励
10 回复数
John_H_Intel2
员工
942 次查看
Have you added any elements to your app in Design mode? After you do that you should see an ionic folder.
0 项奖励
Mark_Z_1
初学者
942 次查看
Ionic project have no design mode right?
0 项奖励
John_H_Intel2
员工
942 次查看
It should.
0 项奖励
Mark_Z_1
初学者
942 次查看
I didn't see the design mode button. Can you show me a screenshot with Ionic Project with Design Mode?
0 项奖励
Chris_P_Intel
员工
942 次查看
If the project was created with App Designer elected, then when you select an .html file in the file browser you should have the option of editing in code or design mode. The button that flips between them is on the toolbar, at the left. (Very obvious). But if you have a different type of file active, the button may not be active. And if no file is selected, or if the project did not elect App Designer when created, then the button won't appear at all.
0 项奖励
Mark_Z_1
初学者
942 次查看
I'm pretty sure we are not talking about the same thing. So I created some screenshots so that we all understand what we are talking about. The MAIN QUESTION is why XDK 1912 create Ionic Project template without Ionic JS files and why is it treated as Game Mode? XDK 1826 create Ionic Project without error. Please see the last screenshot.
Screenshot:
Step 1:
Step 2:
Step 3:
Step 4:
This screenshot is for Ionic Project created using XDK version 1826:
0 项奖励
Chris_P_Intel
员工
942 次查看
The Ionic Sample project was not created with App Designer, it won't open there.  But it otherwise a working Ionic project and can be used a starting place.
If you want an Ionic project with App Designer, just make a new Blank project and elect App Designer. Then you'll be asked what framework to use, select Ionic. Then start inserting controls.
Yes, there is a disconnect there between the two things I mentioned. We'll get that smoothed out sometime in the future.
Hope this helps,
Chris
0 项奖励
Mark_Z_1
初学者
942 次查看
You really don't understand my question... I don't know how to communicate with you. You don't seem to read question in detail. You just simply shoot out unrelated answer to my question. Very disappointed...
0 项奖励
Swati_S_Intel1
942 次查看
Hello Mark,
I understand your question. You are correct. There has been some mix up with the ionic template in this version, it's bringing up wrong template and shows up as a game project.  I have reported the issue, it should be fixed soon.
Thanks for bringing this to our attention. Sorry about the inconvenience.
Swati
0 项奖励
Mark_Z_1
初学者
942 次查看
I'm glad that someone FINALLY understand and saw the problem. Hope the new version will fix this. Thanks.
0 项奖励
回复
