Software Archive
Read-only legacy content
17060 Discussions
XDK Build fail on update to 3240
Isaias_U_
Please help me, I trying to build my app on previus version of intel xdk works always but when I updated It fail. here is my log.
:preDexArmv7Release
:dexArmv7Release
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dex.DexException: Multiple dex files define Landroid/support/v4/accessibilityservice/AccessibilityServiceInfoCompatIcs;
	at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:596)
	at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:554)
	at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:535)
	at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:171)
	at com.android.dx.merge.DexMerger.merge(DexMerger.java:189)
	at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:454)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:303)
	at com.android.dx.command.dexer.Main.run(Main.java:246)
	at com.android.dx.command.dexer.Main.main(Main.java:215)
	at com.android.dx.command.Main.main(Main.java:106)
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':dexArmv7Release'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
  	.../android-sdk/build-tools/21.1.2/dx --dex --output .../SportsEdge/platforms/android/build/intermediates/dex/armv7/release --input-list=.../SportsEdge/platforms/android/build/intermediates/tmp/dex/armv7/release/inputList.txt
  Error Code:
  	2
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 1 mins 19.233 secs
.../SportsEdge/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../SportsEdge/platforms/android/gradlew with args: cdvBuildRelease,-b,.../SportsEdge/platforms/android/build.gradle,--no-daemon
Command finished with error code 1: .../SportsEdge/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../SportsEdge/platforms/android/cordova/build: Command failed with exit code 1
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
PaulF_IntelCorp
Isaias -- please attach the entire detailed build log, the important part is above what you pasted. Attach it as a text file using the "Attach Files to Post" link below the forum post edit window. Please do not paste the entire build log directly into your post.
Isaias_U_
Thanks here is my log
PaulF_IntelCorp
It looks like you are building with CLI 5.1.1, not positive. Also, you are including several intel.xdk plugins. These have been retired and should no longer be use. I believe they are the source of the build problem. Please replace them with the equivalent Cordova plugins (see https://software.intel.com/en-us/xdk/docs/intel-xdk-api-cordova-plugin-methods-properties-events for help). Also, try using CLI 5.4.1 and be sure to allow the XDK to update all of the plugins when you switch to CLI 5.4.1.
Isaias_U_
Hi Paul thank you for your fast response, I have many apps on my intel xdk, this log(attached) is an app with cordova plugins only and the cordova CLI is 5.4.1 and fail too.
PaulF_IntelCorp
Isaias -- the build appears to be complaining about a missing icon. Can you attach your intelxdk.config.additions.xml file and your <project-name>.xdk file? Both are in the root directory of your project.
Isaias_U_
Now I successfully generated the build, Thank for your help and time Paul.
