Software Archive
Read-only legacy content
17060 Discussions
XDK Crashes on large project upload during build (version 3088/3240)
Swati_S_Intel1
Hello Developers,
We have identified an issue where XDK crashes when trying to upload large project during build. This issue happens in versions 3088 and 3240. We are working on a solution for this issue, meanwhile if you are absolutely not able to build, we recommend that you use the older version 2893 which is available to download here : https://software.intel.com/en-us/forums/intel-xdk/topic/623387
Ariska_Hidayat
I have a problem when opening XDK version 2893. But I also have a problem with an iframe in 3357. But apart from that version has not found the problem.
Pamela_H_Intel
2893 will no longer build later this month. So you should use 3357.
So, with the same app, you can (could) build and run in 2893 and not in 3357?
Ariska_Hidayat
Hi, I also have problems with the iframe. But I have a solution to these problems. is to create a new project and then the www folder of the old project I move into a new project. After that I no constraint in the iframe. I hope this helps.
Pamela_H_Intel
Ariska - So you are saying you solved your iframe problem by creating a new project? If so, great work, and thank you for the update. If not, please clarify.
Pamela
