Software Archive
Read-only legacy content
17060 Discussions
XDK crashes when building android app
Guillermo_A_
Every time I try to build up my app it crash. I am trying to build a rpg maker mv project.
What can I do to solve this?
I will put the log :
xdk:client:[2016-04-14T00:48:25.504Z]: (1460594905505): memlim: 767557632
xdk:client:[2016-04-14T00:48:25.508Z]: (1460594905508): Setting NW crash dump to: C:\Users\Usuario\AppData\Local\XDK
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): Intel XDK: 3088
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): System Info:  CPU: 4 X Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz Physical Memory: 8527228928
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): NW: 0.11.7-rc10-dev
xdk:client:[2016-04-14T00:48:25.777Z]: (1460594905777): Created new theme: base
xdk:client:[2016-04-14T00:48:25.777Z]: (1460594905777): Registered new theme: base
xdk:client:[2016-04-14T00:48:25.783Z]: (1460594905783): Current theme is now: base
xdk:client:[2016-04-14T00:48:25.784Z]: (1460594905784): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-04-14T00:48:25.785Z]: (1460594905785): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-04-14T00:48:26.093Z]: (1460594906093): Starting client process initialization
xdk:client:[2016-04-14T00:48:26.122Z]: (1460594906122): NW Cache is up-to-date.
xdk:server:[2016-04-14T00:48:26.685Z]: (1460594906686): memlim: 767557632
xdk:server:[2016-04-14T00:48:26.691Z]: (1460594906691): Setting NW crash dump to: C:\Users\Usuario\AppData\Local\XDK
xdk:server:[2016-04-14T00:48:26.942Z]: (1460594906942): Starting server process initialization
xdk:server:[2016-04-14T00:48:27.087Z]: (1460594907088): Http server started on the standard port 58889
xdk:server:[2016-04-14T00:48:27.111Z]: (1460594907111): NW Cache is up-to-date.
xdk:server:[2016-04-14T00:48:27.625Z]: (1460594907625): Component "core:assert" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:assert" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:component-error" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:component-error" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:command-line-options" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:command-line-options" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:service-error" starting import
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:service-error" finished initialization
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:buffer" starting import
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:buffer" finished initialization
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:signaler" starting import
xdk:server:[2016-04-14T00:48:27.629Z]: (1460594907629): Component "core:signaler" finished initialization
xdk:server:[2016-04-14T00:48:27.629Z]: (1460594907629): Component "core:signaler-group" starting import
xdk:server:[2016-04-14T00:48:27.631Z]: (1460594907631): Component "core:signaler-group" finished initialization
xdk:server:[2016-04-14T00:48:27.631Z]: (1460594907631): Component "core:logger" starting import
xdk:server:[2016-04-14T00:48:27.632Z]: (1460594907632): Component "core:logger" finished initialization
xdk:server:[2016-04-14T00:48:27.632Z]: (1460594907632): Component "core:http-request" starting import
xdk:server:[2016-04-14T00:48:27.633Z]: (1460594907633): Component "core:http-request" finished initialization
xdk:server:[2016-04-14T00:48:27.633Z]: (1460594907633): Component "core:database" starting import
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:database" finished initialization
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:version" starting import
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:version" finished initialization
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:userfs-name-converter" starting import
xdk:server:[2016-04-14T00:48:27.635Z]: (1460594907635): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-04-14T00:48:27.635Z]: (1460594907635): Component "core:crash-handler" starting import
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:crash-handler" finished initialization
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:i18n-support" starting import
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:i18n-support" finished initialization
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:theme" starting import
xdk:server:[2016-04-14T00:48:27.683Z]: (1460594907683): Component "core:theme" finished initialization
xdk:server:[2016-04-14T00:48:27.684Z]: (1460594907684): Component "server:userfs" starting import
xdk:server:[2016-04-14T00:48:27.691Z]: (1460594907691): Component "server:userfs" calling init()
xdk:server:[2016-04-14T00:48:27.732Z]: (1460594907732): Component "server:userfs" finished initialization
xdk:server:[2016-04-14T00:48:27.732Z]: (1460594907732): Component "server:user-profile" starting import
xdk:server:[2016-04-14T00:48:27.736Z]: (1460594907736): Component "server:user-profile" calling init()
xdk:server:[2016-04-14T00:48:27.736Z]: (1460594907736): Component "server:user-profile" finished initialization
xdk:server:[2016-04-14T00:48:27.737Z]: (1460594907737): Component "server:ui-builder" starting import
xdk:server:[2016-04-14T00:48:27.794Z]: (1460594907794): Component "server:ui-builder" calling init()
xdk:server:[2016-04-14T00:48:27.796Z]: (1460594907796): Component "server:ui-builder" finished initialization
xdk:server:[2016-04-14T00:48:27.796Z]: (1460594907796): Component "server:emulator-notification" starting import
xdk:server:[2016-04-14T00:48:27.800Z]: (1460594907800): Component "server:emulator-notification" calling init()
xdk:server:[2016-04-14T00:48:27.801Z]: (1460594907801): Component "server:emulator-notification" finished initialization
xdk:server:[2016-04-14T00:48:27.801Z]: (1460594907801): Component "server:emulator-webserver" starting import
xdk:server:[2016-04-14T00:48:27.802Z]: (1460594907802): Component "server:emulator-webserver" calling init()
xdk:server:[2016-04-14T00:48:27.803Z]: (1460594907803): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-04-14T00:48:27.803Z]: (1460594907803): Component "server:zip-util" starting import
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:zip-util" calling init()
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:zip-util" finished initialization
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:uuid-server" starting import
xdk:server:[2016-04-14T00:48:27.810Z]: (1460594907810): Component "server:uuid-server" calling init()
xdk:server:[2016-04-14T00:48:27.811Z]: (1460594907811): Component "server:uuid-server" finished initialization
xdk:server:[2016-04-14T00:48:27.811Z]: (1460594907811): Component "server:force-download" starting import
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:force-download" calling init()
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:force-download" finished initialization
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:updater" starting import
xdk:server:[2016-04-14T00:48:27.819Z]: (1460594907819): Component "server:updater" calling init()
server:updater:[2016-04-14T00:48:27.819Z]: (1460594907819): config.base-auto
server:updater:[2016-04-14T00:48:27.819Z]: (1460594907819): url=auto
xdk:server:[2016-04-14T00:48:27.820Z]: (1460594907820): Component "server:updater" finished initialization
xdk:server:[2016-04-14T00:48:27.820Z]: (1460594907820): Component "server:editor-node" starting import
xdk:server:[2016-04-14T00:48:27.857Z]: (1460594907857): Component "server:editor-node" calling init()
xdk:server:[2016-04-14T00:48:27.858Z]: (1460594907858): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-04-14T00:48:27.858Z]: (1460594907858): Component "server:cordova-lib" starting import
xdk:server:[2016-04-14T00:48:28.375Z]: (1460594908375): Component "server:cordova-lib" calling init()
xdk:server:[2016-04-14T00:48:28.573Z]: (1460594908573): Component "server:cordova-lib" finished initialization
xdk:server:[2016-04-14T00:48:28.573Z]: (1460594908573): Component "server:api-explorer" starting import
xdk:server:[2016-04-14T00:48:28.581Z]: (1460594908581): Component "server:api-explorer" calling init()
xdk:server:[2016-04-14T00:48:28.667Z]: (1460594908667): Component "server:api-explorer" finished initialization
xdk:server:[2016-04-14T00:48:28.667Z]: (1460594908667): Component "server:plugin-listener" starting import
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:plugin-listener" calling init()
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:plugin-listener" finished initialization
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:git-runner" starting import
xdk:server:[2016-04-14T00:48:28.674Z]: (1460594908674): Component "server:git-runner" calling init()
xdk:server:[2016-04-14T00:48:28.674Z]: (1460594908674): Component "server:git-runner" finished initialization
server:editor-node:[2016-04-14T00:48:28.676Z]: (1460594908676): Starting Brackets node process "D:\Intel XDK\bin\node.exe" "D:\Intel XDK\bin\node-core"
server:editor-node:[2016-04-14T00:48:28.844Z]: (1460594908844): Brackets node is running on port 59479
xdk:server:[2016-04-14T00:48:28.845Z]: (1460594908845): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-04-14T00:48:28.845Z]: (1460594908845): Component "server:ui-builder" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:ui-builder" finished start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:emulator-webserver" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:emulator-webserver" finished start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:editor-node" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:editor-node" finished start()
xdk:server:[2016-04-14T00:48:28.852Z]: (1460594908852): Intel XDK is initialized now
xdk:server:[2016-04-14T00:48:28.852Z]: (1460594908852): Writing to the server data file
xdk:server:[2016-04-14T00:48:28.854Z]: (1460594908854): Wrote server data to "C:\Users\Usuario\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-04-14T00:48:28.895Z]: (1460594908895): Successfully read server data file
xdk:client:[2016-04-14T00:48:29.061Z]: (1460594909061): Component "core:assert" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:assert" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:component-error" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:component-error" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:command-line-options" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:command-line-options" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:service-error" starting import
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:service-error" finished initialization
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:buffer" starting import
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:buffer" finished initialization
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:signaler" starting import
xdk:client:[2016-04-14T00:48:29.064Z]: (1460594909064): Component "core:signaler" finished initialization
xdk:client:[2016-04-14T00:48:29.064Z]: (1460594909064): Component "core:signaler-group" starting import
xdk:client:[2016-04-14T00:48:29.066Z]: (1460594909066): Component "core:signaler-group" finished initialization
xdk:client:[2016-04-14T00:48:29.066Z]: (1460594909066): Component "core:logger" starting import
xdk:client:[2016-04-14T00:48:29.067Z]: (1460594909067): Component "core:logger" finished initialization
xdk:client:[2016-04-14T00:48:29.067Z]: (1460594909067): Component "core:http-request" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:http-request" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:version" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:version" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:exit-notifier" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:exit-notifier" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:userfs-name-converter" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909069): Component "core:crash-handler" starting import
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909069): Component "core:crash-handler" finished initialization
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909070): Component "core:analytics" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:analytics" finished initialization
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:i18n-support" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:i18n-support" finished initialization
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:theme" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:theme" finished initialization
xdk:client:[2016-04-14T00:48:29.079Z]: (1460594909079): Analytics ID: 8f0b9b02-7fda-44db-ae35-f01f8384f966
xdk:client:[2016-04-14T00:48:29.080Z]: (1460594909080): onExit listener 0:
    at Object.exports.onExit (D:\Intel XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (D:\Intel XDK\xdk\core-modules\public\analytics.js:17:1438)
    at D:\Intel XDK\xdk\core-modules\public\analytics.js:17:6219
    at D:\Intel XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (D:\Intel XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (D:\Intel XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (D:\Intel XDK\xdk\node_modules\q\q.js:796:13)
    at D:\Intel XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (D:\Intel XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:app" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:help-helper" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:nativefs" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:document-manager" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:project-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:aa-controller" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:build-validator" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:active-sync" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:apk-installer" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:appcenter-options" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-cocos2d" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-phaser" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-pixi" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-easeljs" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-plain" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-render-frame" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-util" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:bower-package-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:services-tab" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:editor" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:live-preview" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-services" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-feeds" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:merged-feed" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-services-ext" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-service-utils" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:cert-manager" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:account-settings" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:ui-builder-client" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:project-meta" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:contenttype-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:editor-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:platform-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:projecttype-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:library-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:cordova-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:service-method" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:settings-db" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:adb" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:iosdb" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:device" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:device-discovery" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:dialog-box" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:test-local-server" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:quick-tour" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:hot-keys" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:persistance" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:tabs" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:hash-utils" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:file-watcher" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:tool-tip" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:cordova" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:settings-ui" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:external-links" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:external-editors-runner" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:project-list-load" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:upload-manager" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:git-manager" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:new-project-creator" starting import
xdk:client:[2016-04-14T00:48:29.174Z]: (1460594909174): Component "client:help-helper" finished initialization
xdk:client:[2016-04-14T00:48:29.175Z]: (1460594909175): Component "client:nativefs" finished initialization
xdk:client:[2016-04-14T00:48:29.191Z]: (1460594909191): Component "client:active-sync" calling init()
xdk:client:[2016-04-14T00:48:29.192Z]: (1460594909192): Component "client:active-sync" finished initialization
xdk:client:[2016-04-14T00:48:29.194Z]: (1460594909194): Component "client:apk-installer" calling init()
xdk:client:[2016-04-14T00:48:29.194Z]: (1460594909194): Component "client:apk-installer" finished initialization
xdk:client:[2016-04-14T00:48:29.223Z]: (1460594909223): Component "client:resource-render-frame" calling init()
xdk:client:[2016-04-14T00:48:29.223Z]: (1460594909223): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.224Z]: (1460594909224): Component "client:resource-util" calling init()
xdk:client:[2016-04-14T00:48:29.224Z]: (1460594909224): Component "client:resource-util" finished initialization
xdk:client:[2016-04-14T00:48:29.231Z]: (1460594909231): Component "client:backend-services" calling init()
xdk:client:[2016-04-14T00:48:29.232Z]: (1460594909232): Component "client:backend-services" finished initialization
xdk:client:[2016-04-14T00:48:29.233Z]: (1460594909233): Component "client:backend-feeds" calling init()
xdk:client:[2016-04-14T00:48:29.233Z]: (1460594909233): Component "client:backend-feeds" finished initialization
xdk:client:[2016-04-14T00:48:29.234Z]: (1460594909234): Component "client:merged-feed" finished initialization
xdk:client:[2016-04-14T00:48:29.235Z]: (1460594909235): Component "client:backend-services-ext" calling init()
xdk:client:[2016-04-14T00:48:29.235Z]: (1460594909235): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-04-14T00:48:29.236Z]: (1460594909236): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-04-14T00:48:29.242Z]: (1460594909242): Component "client:project-meta" calling init()
xdk:client:[2016-04-14T00:48:29.243Z]: (1460594909243): Component "client:project-meta" finished initialization
xdk:client:[2016-04-14T00:48:29.249Z]: (1460594909249): Component "client:service-method" finished initialization
xdk:client:[2016-04-14T00:48:29.251Z]: (1460594909251): Component "client:settings-db" calling init()
xdk:client:[2016-04-14T00:48:29.251Z]: (1460594909251): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.252Z]: (1460594909252): Component "client:adb" calling init()
xdk:client:[2016-04-14T00:48:29.263Z]: (1460594909263): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.264Z]: (1460594909264): Component "client:iosdb" calling init()
xdk:client:[2016-04-14T00:48:29.264Z]: (1460594909264): Component "client:iosdb" finished initialization
xdk:client:[2016-04-14T00:48:29.271Z]: (1460594909271): Component "client:persistance" calling init()
xdk:client:[2016-04-14T00:48:29.271Z]: (1460594909271): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.273Z]: (1460594909273): Component "client:file-watcher" calling init()
xdk:client:[2016-04-14T00:48:29.273Z]: (1460594909273): Component "client:file-watcher" finished initialization
xdk:client:[2016-04-14T00:48:29.277Z]: (1460594909277): Component "client:external-links" finished initialization
xdk:client:[2016-04-14T00:48:29.278Z]: (1460594909278): Component "client:external-editors-runner" calling init()
xdk:client:[2016-04-14T00:48:29.278Z]: (1460594909278): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-04-14T00:48:29.279Z]: (1460594909279): Component "client:project-list-load" calling init()
xdk:client:[2016-04-14T00:48:29.279Z]: (1460594909279): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.281Z]: (1460594909281): Component "client:upload-manager" calling init()
xdk:client:[2016-04-14T00:48:29.281Z]: (1460594909281): Component "client:upload-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.282Z]: (1460594909282): Component "client:git-manager" calling init()
client:git-manager:[2016-04-14T00:48:29.283Z]: (1460594909283): git path =  D:\Intel XDK\bin\git\bin\git.exe
xdk:client:[2016-04-14T00:48:29.283Z]: (1460594909283): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.284Z]: (1460594909284): Component "client:new-project-creator" calling init()
xdk:client:[2016-04-14T00:48:29.285Z]: (1460594909285): Component "client:new-project-creator" finished initialization
xdk:client:[2016-04-14T00:48:29.288Z]: (1460594909288): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.294Z]: (1460594909294): Component "client:build-validator" finished initialization
xdk:client:[2016-04-14T00:48:29.309Z]: (1460594909309): Component "client:tool-tip" finished initialization
xdk:client:[2016-04-14T00:48:29.319Z]: (1460594909319): Component "client:ui-builder-client" calling init()
xdk:client:[2016-04-14T00:48:29.319Z]: (1460594909319): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-04-14T00:48:29.321Z]: (1460594909321): Component "client:dialog-box" finished initialization
xdk:client:[2016-04-14T00:48:29.322Z]: (1460594909322): Component "client:hot-keys" calling init()
xdk:client:[2016-04-14T00:48:29.322Z]: (1460594909323): Component "client:hot-keys" finished initialization
xdk:client:[2016-04-14T00:48:29.327Z]: (1460594909327): Component "client:settings-ui" finished initialization
xdk:client:[2016-04-14T00:48:29.331Z]: (1460594909331): Component "client:document-manager" calling init()
xdk:client:[2016-04-14T00:48:29.332Z]: (1460594909332): Component "client:document-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.351Z]: (1460594909351): Component "client:aa-controller" calling init()
xdk:client:[2016-04-14T00:48:29.351Z]: (1460594909351): Component "client:aa-controller" finished initialization
xdk:client:[2016-04-14T00:48:29.431Z]: (1460594909431): Component "client:contenttype-registry" calling init()
xdk:client:[2016-04-14T00:48:29.432Z]: (1460594909432): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.433Z]: (1460594909433): Component "client:editor-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.442Z]: (1460594909442): Component "client:library-registry" calling init()
xdk:client:[2016-04-14T00:48:29.442Z]: (1460594909442): Component "client:library-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.450Z]: (1460594909450): Component "client:device-discovery" calling init()
xdk:client:[2016-04-14T00:48:29.451Z]: (1460594909451): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.452Z]: (1460594909452): Component "client:hash-utils" finished initialization
xdk:client:[2016-04-14T00:48:29.507Z]: (1460594909507): Component "client:cordova" calling init()
xdk:client:[2016-04-14T00:48:29.507Z]: (1460594909507): Component "client:cordova" waiting for delayed initialization
client:adb:[2016-04-14T00:48:29.533Z]: (1460594909533): Using existing adb at "D:\Intel XDK\bin\adb\adb.exe"
xdk:client:[2016-04-14T00:48:29.546Z]: (1460594909546): Component "client:resource-manager" calling init()
xdk:client:[2016-04-14T00:48:29.547Z]: (1460594909547): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.558Z]: (1460594909558): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-04-14T00:48:29.558Z]: (1460594909558): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-04-14T00:48:29.561Z]: (1460594909561): Component "client:resource-phaser" calling init()
xdk:client:[2016-04-14T00:48:29.561Z]: (1460594909561): Component "client:resource-phaser" finished initialization
xdk:client:[2016-04-14T00:48:29.563Z]: (1460594909563): Component "client:resource-pixi" calling init()
xdk:client:[2016-04-14T00:48:29.563Z]: (1460594909563): Component "client:resource-pixi" finished initialization
xdk:client:[2016-04-14T00:48:29.564Z]: (1460594909564): Component "client:resource-easeljs" calling init()
xdk:client:[2016-04-14T00:48:29.564Z]: (1460594909564): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-04-14T00:48:29.565Z]: (1460594909565): Component "client:resource-plain" calling init()
xdk:client:[2016-04-14T00:48:29.565Z]: (1460594909565): Component "client:resource-plain" finished initialization
xdk:client:[2016-04-14T00:48:29.573Z]: (1460594909573): Component "client:cordova-registry" calling init()
xdk:client:[2016-04-14T00:48:29.573Z]: (1460594909573): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.578Z]: (1460594909578): Component "client:appcenter-options" calling init()
xdk:client:[2016-04-14T00:48:29.579Z]: (1460594909579): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.581Z]: (1460594909581): Component "client:services-tab" calling init()
xdk:client:[2016-04-14T00:48:29.582Z]: (1460594909582): Component "client:services-tab" finished initialization
xdk:client:[2016-04-14T00:48:29.583Z]: (1460594909583): Component "client:test-local-server" calling init()
xdk:client:[2016-04-14T00:48:29.610Z]: (1460594909610): Component "client:test-local-server" finished initialization
xdk:client:[2016-04-14T00:48:29.611Z]: (1460594909611): Component "client:tabs" finished initialization
xdk:client:[2016-04-14T00:48:29.622Z]: (1460594909622): Component "client:app" calling init()
xdk:client:[2016-04-14T00:48:29.634Z]: (1460594909634): Component "client:app" finished initialization
xdk:client:[2016-04-14T00:48:29.680Z]: (1460594909680): Component "client:cert-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.687Z]: (1460594909687): Component "client:quick-tour" calling init()
xdk:client:[2016-04-14T00:48:29.687Z]: (1460594909687): Component "client:quick-tour" finished initialization
xdk:client:[2016-04-14T00:48:29.696Z]: (1460594909697): Component "client:project-manager" calling init()
xdk:client:[2016-04-14T00:48:29.697Z]: (1460594909697): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.702Z]: (1460594909702): Component "client:projects-renderers" calling init()
xdk:client:[2016-04-14T00:48:29.702Z]: (1460594909702): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.703Z]: (1460594909703): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-04-14T00:48:29.703Z]: (1460594909703): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-04-14T00:48:29.718Z]: (1460594909718): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-04-14T00:48:29.718Z]: (1460594909718): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.727Z]: (1460594909727): Component "client:account-settings" calling init()
xdk:client:[2016-04-14T00:48:29.727Z]: (1460594909727): Component "client:account-settings" finished initialization
xdk:client:[2016-04-14T00:48:29.731Z]: (1460594909731): Component "client:platform-registry" calling init()
xdk:client:[2016-04-14T00:48:29.732Z]: (1460594909732): Component "client:platform-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.733Z]: (1460594909733): Component "client:projecttype-registry" calling init()
xdk:client:[2016-04-14T00:48:29.734Z]: (1460594909734): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.738Z]: (1460594909738): Component "client:device" calling init()
xdk:client:[2016-04-14T00:48:29.807Z]: (1460594909807): Component "client:device" finished initialization
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:navbar" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:tweets" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:projects-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:test-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:profilingTab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:emulator" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:remote-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:build-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:build-service" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:bower-client" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:editor-tab" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:account" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:project-selector" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:publish-tab" starting import
xdk:client:[2016-04-14T00:48:29.815Z]: (1460594909815): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.815Z]: (1460594909815): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.817Z]: (1460594909817): Component "client:adb" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.834Z]: (1460594909834): Component "client:bower-package-manager" calling init()
xdk:client:[2016-04-14T00:48:29.835Z]: (1460594909835): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.852Z]: (1460594909852): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-04-14T00:48:29.881Z]: (1460594909881): Custom Git Client Path is D:\Intel XDK\bin\git\bin\git.exe
client:git-manager:[2016-04-14T00:48:29.881Z]: (1460594909881): Auto-Proxy setting is true
xdk:client:[2016-04-14T00:48:29.883Z]: (1460594909883): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.910Z]: (1460594909910): Component "client:editor" calling init()
xdk:client:[2016-04-14T00:48:29.910Z]: (1460594909910): Component "client:editor" finished initialization
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:live-preview" calling init()
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:live-preview" finished initialization
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-04-14T00:48:29.912Z]: (1460594909912): Component "client:editor-tab" calling init()
xdk:client:[2016-04-14T00:48:29.921Z]: (1460594909921): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.937Z]: (1460594909937): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-04-14T00:48:29.938Z]: (1460594909938): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-04-14T00:48:29.943Z]: (1460594909943): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-04-14T00:48:29.943Z]: (1460594909943): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" calling init()
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" finished initialization
xdk:client:[2016-04-14T00:48:29.976Z]: (1460594909976): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.983Z]: (1460594909983): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.027Z]: (1460594910027): Component "client:account" getting UI region for "account"
xdk:client:[2016-04-14T00:48:30.027Z]: (1460594910027): Component "client:account" calling init()
xdk:client:[2016-04-14T00:48:30.032Z]: (1460594910032): Component "client:account" finished initialization
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" calling init()
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" finished initialization
xdk:client:[2016-04-14T00:48:30.039Z]: (1460594910039): Component "client:tweets" finished initialization
xdk:client:[2016-04-14T00:48:30.040Z]: (1460594910040): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-04-14T00:48:30.040Z]: (1460594910040): Component "client:projects-tab" calling init()
xdk:client:[2016-04-14T00:48:30.041Z]: (1460594910041): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.042Z]: (1460594910042): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-04-14T00:48:30.043Z]: (1460594910043): Component "client:test-tab" calling init()
xdk:client:[2016-04-14T00:48:30.043Z]: (1460594910043): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.053Z]: (1460594910053): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-04-14T00:48:30.053Z]: (1460594910053): Component "client:emulator" calling init()
xdk:client:[2016-04-14T00:48:30.056Z]: (1460594910056): Component "client:emulator" finished initialization
xdk:client:[2016-04-14T00:48:30.065Z]: (1460594910065): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-04-14T00:48:30.065Z]: (1460594910065): Component "client:remote-tab" calling init()
xdk:client:[2016-04-14T00:48:30.164Z]: (1460594910164): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.178Z]: (1460594910178): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.183Z]: (1460594910183): Component "client:cordova" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.187Z]: (1460594910187): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-04-14T00:48:30.187Z]: (1460594910187): Component "client:navbar" calling init()
client:navbar:[2016-04-14T00:48:30.188Z]: (1460594910188): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-04-14T00:48:30.188Z]: (1460594910188): Component "client:navbar" finished initialization
xdk:client:[2016-04-14T00:48:30.255Z]: (1460594910255): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-04-14T00:48:30.256Z]: (1460594910256): Component "client:build-tab" calling init()
xdk:client:[2016-04-14T00:48:30.266Z]: (1460594910266): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.281Z]: (1460594910281): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-04-14T00:48:30.281Z]: (1460594910281): Component "client:publish-tab" calling init()
xdk:client:[2016-04-14T00:48:30.288Z]: (1460594910288): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.290Z]: (1460594910290): Component "client:publish-tab" finished initialization
xdk:client:[2016-04-14T00:48:30.336Z]: (1460594910336): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-04-14T00:48:30.336Z]: (1460594910336): Component "client:bower-client" calling init()
xdk:client:[2016-04-14T00:48:30.337Z]: (1460594910337): Component "client:bower-client" finished initialization
xdk:client:[2016-04-14T00:48:30.434Z]: (1460594910434): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-04-14T00:48:30.434Z]: (1460594910434): Component "client:profilingTab" calling init()
xdk:client:[2016-04-14T00:48:30.436Z]: (1460594910436): Component "client:profilingTab" finished initialization
xdk:client:[2016-04-14T00:48:30.506Z]: (1460594910506): memmrk:    34606752    48555136
xdk:server:[2016-04-14T00:48:31.687Z]: (1460594911687): memmrk:    27384636    43419136
xdk:client:[2016-04-14T00:48:31.775Z]: (1460594911775): Component "client:persistance" finished delayed initialization
client:appcenter-options:[2016-04-14T00:48:32.046Z]: (1460594912046): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-04-14T00:48:32.047Z]: (1460594912047): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.050Z]: (1460594912050): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.069Z]: (1460594912069): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.386Z]: (1460594912386): Component "client:project-manager" finished delayed initialization
client:cordova:[2016-04-14T00:48:32.471Z]: (1460594912471): { xdkProjectStatus: 'all_same',
  pluginStatus:
   { 'cordova-plugin-device': 'same',
     'cordova-plugin-splashscreen': 'same',
     'cordova-plugin-statusbar': 'same' } }
xdk:client:[2016-04-14T00:48:32.475Z]: (1460594912475): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-list" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-info" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-create-list" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-create-info" starting import
xdk:client:[2016-04-14T00:48:33.160Z]: (1460594913160): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-04-14T00:48:33.161Z]: (1460594913161): Component "client:projects-list" calling init()
xdk:client:[2016-04-14T00:48:33.162Z]: (1460594913162): Component "client:projects-list" finished initialization
xdk:client:[2016-04-14T00:48:33.164Z]: (1460594913164): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-04-14T00:48:33.164Z]: (1460594913164): Component "client:projects-info" calling init()
xdk:client:[2016-04-14T00:48:33.165Z]: (1460594913165): Component "client:projects-info" finished initialization
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" calling init()
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" finished initialization
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" calling init()
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" finished initialization
xdk:client:[2016-04-14T00:48:36.148Z]: (1460594916148): memmrk:    44739924    62750336
xdk:server:[2016-04-14T00:48:36.689Z]: (1460594916689): memmrk:    28567296    43419136
xdk:client:[2016-04-14T00:48:39.341Z]: (1460594919341): onExitRequest listener 1:
    at Object.exports.onExitRequest (D:\Intel XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
    at Object.<anonymous> (file:///D:/Intel%20XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
    at Object.context.execCb (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
    at Object.Module.check (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
    at Object.<anonymous> (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
    at file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
    at file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
    at each (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
    at Object.Module.emit (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:client:[2016-04-14T00:48:41.146Z]: (1460594921146): memmrk:    56869056    71867136
xdk:server:[2016-04-14T00:48:41.690Z]: (1460594921690): memmrk:    20673188    43419136
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : Container provided by brackets :
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-04-14T00:48:42.477Z]: (1460594922477): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:42.479Z]: (1460594922479): Component "client:app" calling start()
xdk:client:[2016-04-14T00:48:42.501Z]: (1460594922501): Component "client:app" finished start()
xdk:client:[2016-04-14T00:48:42.501Z]: (1460594922501): Component "client:navbar" calling start()
xdk:client:[2016-04-14T00:48:42.518Z]: (1460594922518): Component "client:navbar" finished start()
xdk:client:[2016-04-14T00:48:42.518Z]: (1460594922518): Component "client:project-manager" calling start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:project-manager" finished start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:aa-controller" calling start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:aa-controller" finished start()
xdk:client:[2016-04-14T00:48:42.520Z]: (1460594922520): Component "client:projects-tab" calling start()
xdk:client:[2016-04-14T00:48:42.527Z]: (1460594922527): Component "client:projects-tab" finished start()
xdk:client:[2016-04-14T00:48:42.527Z]: (1460594922527): Component "client:projects-list" calling start()
xdk:client:[2016-04-14T00:48:42.530Z]: (1460594922530): Component "client:projects-list" finished start()
xdk:client:[2016-04-14T00:48:42.530Z]: (1460594922530): Component "client:projects-info" calling start()
xdk:client:[2016-04-14T00:48:42.631Z]: (1460594922631): Component "client:projects-info" finished start()
xdk:client:[2016-04-14T00:48:42.631Z]: (1460594922631): Component "client:projects-create-list" calling start()
xdk:client:[2016-04-14T00:48:42.675Z]: (1460594922675): Component "client:projects-create-list" finished start()
xdk:client:[2016-04-14T00:48:42.675Z]: (1460594922675): Component "client:projects-create-info" calling start()
xdk:client:[2016-04-14T00:48:42.682Z]: (1460594922682): Component "client:projects-create-info" finished start()
xdk:client:[2016-04-14T00:48:42.682Z]: (1460594922682): Component "client:test-tab" calling start()
xdk:client:[2016-04-14T00:48:42.686Z]: (1460594922686): Component "client:test-tab" finished start()
xdk:client:[2016-04-14T00:48:42.686Z]: (1460594922686): Component "client:profilingTab" calling start()
xdk:client:[2016-04-14T00:48:42.739Z]: (1460594922739): Component "client:profilingTab" finished start()
xdk:client:[2016-04-14T00:48:42.739Z]: (1460594922739): Component "client:emulator" calling start()
xdk:client:[2016-04-14T00:48:42.740Z]: (1460594922740): Component "client:emulator" finished start()
xdk:client:[2016-04-14T00:48:42.740Z]: (1460594922740): Component "client:remote-tab" calling start()
xdk:client:[2016-04-14T00:48:42.746Z]: (1460594922746): onExitRequest listener 2:
    at Object.myExports.start (file:///D:/Intel%20XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
    at resumeClientInit (D:\Intel XDK\xdk\core-modules\private\main.js:17:12040)
    at D:\Intel XDK\xdk\core-modules\private\main.js:17:1734
xdk:client:[2016-04-14T00:48:42.747Z]: (1460594922747): Component "client:remote-tab" finished start()
xdk:client:[2016-04-14T00:48:42.747Z]: (1460594922747): Component "client:build-tab" calling start()
xdk:client:[2016-04-14T00:48:42.750Z]: (1460594922750): Component "client:build-tab" finished start()
xdk:client:[2016-04-14T00:48:42.750Z]: (1460594922750): Component "client:active-sync" calling start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:active-sync" finished start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:apk-installer" calling start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:apk-installer" finished start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:resource-manager" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-manager" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-phaser" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-phaser" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-pixi" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-pixi" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-easeljs" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-easeljs" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-plain" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-plain" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-render-frame" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-render-frame" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-util" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-util" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:bower-client" calling start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:bower-client" finished start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor" calling start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor" finished start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor-tab" calling start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:editor-tab" finished start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:live-preview" calling start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:live-preview" finished start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:account" calling start()
xdk:client:[2016-04-14T00:48:42.788Z]: (1460594922788): Component "client:account" finished start()
xdk:client:[2016-04-14T00:48:42.788Z]: (1460594922788): Component "client:project-selector" calling start()
xdk:client:[2016-04-14T00:48:42.790Z]: (1460594922790): Component "client:project-selector" finished start()
xdk:client:[2016-04-14T00:48:42.790Z]: (1460594922790): Component "client:ui-builder-client" calling start()
xdk:client:[2016-04-14T00:48:42.791Z]: (1460594922791): Component "client:ui-builder-client" finished start()
xdk:client:[2016-04-14T00:48:42.791Z]: (1460594922791): Component "client:project-meta" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:project-meta" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:cordova-registry" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:cordova-registry" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:adb" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:adb" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:iosdb" calling start()
xdk:client:[2016-04-14T00:48:42.794Z]: (1460594922794): Component "client:iosdb" finished start()
xdk:client:[2016-04-14T00:48:42.794Z]: (1460594922794): Component "client:device-discovery" calling start()
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): onExitRequest listener 3:
    at Object.start (file:///D:/Intel%20XDK/xdk/components/client/device-discovery/device-discovery.js:17:9195)
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): Component "client:device-discovery" finished start()
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): Component "client:test-local-server" calling start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:test-local-server" finished start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:quick-tour" calling start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:quick-tour" finished start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:hot-keys" calling start()
xdk:client:[2016-04-14T00:48:42.799Z]: (1460594922799): Component "client:hot-keys" finished start()
xdk:client:[2016-04-14T00:48:42.799Z]: (1460594922799): Component "client:persistance" calling start()
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): onExit listener 4:
    at Object.start (file:///D:/Intel%20XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): Component "client:persistance" finished start()
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): Component "client:file-watcher" calling start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:file-watcher" finished start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:cordova" calling start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:cordova" finished start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:external-editors-runner" calling start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:external-editors-runner" finished start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:upload-manager" calling start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:upload-manager" finished start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:publish-tab" calling start()
xdk:client:[2016-04-14T00:48:42.805Z]: (1460594922805): onExitRequest listener 5:
    at AutofillController.registerForEvents_ (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
    at new AutofillController (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
    at Object.myExports.start (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-04-14T00:48:42.849Z]: (1460594922849): Component "client:publish-tab" finished start()
xdk:client:[2016-04-14T00:48:42.851Z]: (1460594922851): Intel XDK is initialized now
bower-package-manager:[2016-04-14T00:48:42.896Z]: (1460594922896): Bower packages not found { [Error: An error ocurred while trying to check for the file "C:/Users/Usuario/Documents/TheTower/bower.json".]
  code: 22,
  message: 'An error ocurred while trying to check for the file "C:/Users/Usuario/Documents/TheTower/bower.json".',
  originalMessage: 'NotFound',
  originalError: null }
client:build-tab:[2016-04-14T00:48:43.032Z]: (1460594923032): [refreshPage] Unable to generate project hash. { message_: 'Cannot generate app id without user identifiers',
  code_: null,
  componentName_: null,
  stack_: 'Error\n    at Object.createXdkAppId (D:\\Intel XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n    at Object.exports.generateProjectHash (file:///D:/Intel%20XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n    at _refreshPage (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:796:13)\n    at D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:604:44',
  httpCode_: 400 }
client:build-tab:[2016-04-14T00:48:43.033Z]: (1460594923033): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2016-04-14T00:48:43.049Z]: (1460594923049): onExitRequest listener 6:
    at file:///D:/Intel%20XDK/xdk/components/client/project-manager/project-manager.js:18:10467
    at _fulfilled (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:834:54)
    at self.promiseDispatch.done (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:863:30)
    at Promise.promise.promiseDispatch (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:796:13)
    at file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:604:44
    at runSingle (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:137:13)
    at flush (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:125:13)
    at process._tickCallback (node.js:393:11)
builds:[2016-04-14T00:48:43.162Z]: (1460594923163): Error building UI for: certificateId
client:navbar:[2016-04-14T00:48:44.312Z]: (1460594924313): pollForUpdates called
client:build-tab:[2016-04-14T00:48:44.316Z]: (1460594924316): [refreshPage] projectId PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.316Z]: (1460594924316): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2016-04-14T00:48:44.318Z]: (1460594924318): [getBuildTargets] Getting available targets for project PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.319Z]: (1460594924319): [refreshProjectInfo] Getting project info.
client:build-tab:[2016-04-14T00:48:44.320Z]: (1460594924320): [refreshBuildAssetsDate] Getting latest upload date for project files
client:build-tab:[2016-04-14T00:48:44.700Z]: (1460594924700): [getBuildTargets] Targets retrieved for project PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.739Z]: (1460594924739): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-14T00:48:44.739Z]: (1460594924739): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-14T00:48:44.748Z]: (1460594924748): [startUpdateStatusProcess] Starting build pulling process. Project: PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.748Z]: (1460594924748): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2016-04-14T00:48:44.750Z]: (1460594924750): [startUpdateStatusProcess] Starting polling. Project: PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:publish-tab:[2016-04-14T00:48:45.410Z]: (1460594925410): Stores data feed has been successfully loaded.
xdk:client:[2016-04-14T00:48:46.147Z]: (1460594926147): memmrk:    52901860    79968256
xdk:server:[2016-04-14T00:48:46.691Z]: (1460594926691): memmrk:    21818604    29832704
client:navbar:[2016-04-14T00:48:46.771Z]: (1460594926771): polling up-to-date
client:build-service:[2016-04-14T00:48:49.118Z]: (1460594929118): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2016-04-14T00:48:49.119Z]: (1460594929119): [updatePageState] Set State: PAGE_BUILDING
client:build-tab:[2016-04-14T00:48:49.125Z]: (1460594929125): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-14T00:48:49.125Z]: (1460594929125): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-14T00:48:49.413Z]: (1460594929413): [refreshBuildAssetsDate] latest upload date Sat Apr 02 2016 22:17:12 GMT-0300 (Hora estándar de Argentina)
xdk:client:[2016-04-14T00:48:51.165Z]: (1460594931165): memmrk:    61110528    84494080
client:services-tab:[2016-04-14T00:48:51.369Z]: (1460594931369): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2016-04-14T00:48:51.594Z]: (1460594931594): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2016-04-14T00:48:51.598Z]: (1460594931598): Both iframes loaded promise resolved.
client:services-tab:[2016-04-14T00:48:51.620Z]: (1460594931620): Calling postmessage for user refresh.
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): main container window : true
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): main container document : true
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): component:services-tab:postMessageToWindow target = user
xdk:server:[2016-04-14T00:48:51.691Z]: (1460594931691): memmrk:    65924232    80968448
xdk:client:[2016-04-14T00:48:56.167Z]: (1460594936167): memmrk:    65659568    87528960
xdk:server:[2016-04-14T00:48:56.692Z]: (1460594936692): memmrk:    66432200    80968448
xdk:client:[2016-04-14T00:49:01.167Z]: (1460594941167): memmrk:    65834520    87528960
xdk:server:[2016-04-14T00:49:01.692Z]: (1460594941692): memmrk:    66441856    80968448
xdk:client:[2016-04-14T00:49:06.168Z]: (1460594946168): memmrk:    65943872    87528960
xdk:server:[2016-04-14T00:49:06.692Z]: (1460594946692): memmrk:    26121688    63732736
xdk:client:[2016-04-14T00:49:11.168Z]: (1460594951168): memmrk:    66114312    87528960
xdk:server:[2016-04-14T00:49:11.693Z]: (1460594951693): memmrk:    26134776    63732736
xdk:server:[2016-04-14T00:49:16.693Z]: (1460594956693): memmrk:    22626948    34911104
xdk:client:[2016-04-14T00:49:17.146Z]: (1460594957146): memmrk:    50587320    66794880
xdk:server:[2016-04-14T00:49:21.694Z]: (1460594961694): memmrk:    20617756    34911104
xdk:client:[2016-04-14T00:49:22.145Z]: (1460594962145): memmrk:    43929536    58242816
xdk:server:[2016-04-14T00:49:26.695Z]: (1460594966695): memmrk:    20627784    34911104
xdk:client:[2016-04-14T00:49:27.148Z]: (1460594967148): memmrk:    42511592    56223616
xdk:server:[2016-04-14T00:49:31.695Z]: (1460594971695): memmrk:    20634868    34911104
xdk:client:[2016-04-14T00:49:32.148Z]: (1460594972148): memmrk:    42256032    55220096
xdk:server:[2016-04-14T00:49:36.695Z]: (1460594976695): memmrk:    20641936    34911104
xdk:client:[2016-04-14T00:49:37.147Z]: (1460594977147): memmrk:    42527184    54237312
xdk:server:[2016-04-14T00:49:41.695Z]: (1460594981695): memmrk:    20650220    34911104
xdk:client:[2016-04-14T00:49:42.147Z]: (1460594982147): memmrk:    41296816    54237312
xdk:server:[2016-04-14T00:49:46.696Z]: (1460594986696): memmrk:    20657288    34911104
xdk:client:[2016-04-14T00:49:47.147Z]: (1460594987147): memmrk:    41468824    54237312
xdk:server:[2016-04-14T00:49:51.696Z]: (1460594991696): memmrk:    20664372    34911104
xdk:client:[2016-04-14T00:49:52.147Z]: (1460594992147): memmrk:    41578004    54237312
xdk:server:[2016-04-14T00:49:56.697Z]: (1460594996697): memmrk:    20671440    34911104
xdk:client:[2016-04-14T00:49:57.147Z]: (1460594997147): memmrk:    41742972    54237312
xdk:server:[2016-04-14T00:50:01.696Z]: (1460595001696): memmrk:    20678508    34911104
xdk:client:[2016-04-14T00:50:02.146Z]: (1460595002146): memmrk:    41848404    54237312
xdk:server:[2016-04-14T00:50:06.697Z]: (1460595006697): memmrk:    20685592    34911104
xdk:client:[2016-04-14T00:50:07.146Z]: (1460595007146): memmrk:    42043280    54237312
xdk:server:[2016-04-14T00:50:11.697Z]: (1460595011697): memmrk:    20692656    34911104
xdk:client:[2016-04-14T00:50:12.147Z]: (1460595012147): memmrk:    42232132    54237312
xdk:server:[2016-04-14T00:50:16.697Z]: (1460595016697): memmrk:    20699724    34911104
xdk:client:[2016-04-14T00:50:17.146Z]: (1460595017146): memmrk:    41655992    54237312
xdk:server:[2016-04-14T00:50:21.698Z]: (1460595021698): memmrk:    20706792    34911104
xdk:client:[2016-04-14T00:50:22.147Z]: (1460595022147): memmrk:    41760912    54237312
xdk:server:[2016-04-14T00:50:26.697Z]: (1460595026697): memmrk:    20713860    34911104
xdk:client:[2016-04-14T00:50:27.147Z]: (1460595027147): memmrk:    41919840    54237312
xdk:server:[2016-04-14T00:50:31.698Z]: (1460595031698): memmrk:    20723516    34911104
xdk:client:[2016-04-14T00:50:32.146Z]: (1460595032146): memmrk:    42026024    54237312
xdk:server:[2016-04-14T00:50:36.699Z]: (1460595036699): memmrk:    20730568    34911104
xdk:client:[2016-04-14T00:50:37.146Z]: (1460595037146): memmrk:    42298548    54237312
xdk:server:[2016-04-14T00:50:41.699Z]: (1460595041699): memmrk:    20737636    34911104
xdk:client:[2016-04-14T00:50:42.147Z]: (1460595042147): memmrk:    42467964    54237312
xdk:server:[2016-04-14T00:50:46.700Z]: (1460595046700): memmrk:    20744688    34911104
xdk:client:[2016-04-14T00:50:47.147Z]: (1460595047147): memmrk:    42479000    55240832
xdk:server:[2016-04-14T00:50:51.701Z]: (1460595051701): memmrk:    20751756    34911104
xdk:client:[2016-04-14T00:50:52.148Z]: (1460595052148): memmrk:    43076112    55240832
xdk:server:[2016-04-14T00:50:56.701Z]: (1460595056701): memmrk:    20759952    34911104
xdk:client:[2016-04-14T00:50:57.148Z]: (1460595057148): memmrk:    43254328    55240832
xdk:server:[2016-04-14T00:51:01.701Z]: (1460595061701): memmrk:    20768184    34911104
xdk:client:[2016-04-14T00:51:02.150Z]: (1460595062150): memmrk:    43359112    55240832
xdk:server:[2016-04-14T00:51:06.701Z]: (1460595066701): memmrk:    20778336    34911104
xdk:client:[2016-04-14T00:51:07.150Z]: (1460595067150): memmrk:    43515756    55240832
xdk:server:[2016-04-14T00:51:11.702Z]: (1460595071702): memmrk:    20785404    34911104
xdk:client:[2016-04-14T00:51:12.151Z]: (1460595072151): memmrk:    42974660    58353664
xdk:server:[2016-04-14T00:51:16.701Z]: (1460595076701): memmrk:    20792472    34911104
xdk:client:[2016-04-14T00:51:17.152Z]: (1460595077152): memmrk:    43128868    58353664
xdk:server:[2016-04-14T00:51:21.702Z]: (1460595081702): memmrk:    20799524    34911104
xdk:client:[2016-04-14T00:51:22.153Z]: (1460595082153): memmrk:    43232468    58353664
xdk:server:[2016-04-14T00:51:26.701Z]: (1460595086702): memmrk:    20812656    34911104
xdk:client:[2016-04-14T00:51:27.154Z]: (1460595087154): memmrk:    43386656    58353664
xdk:server:[2016-04-14T00:51:31.702Z]: (1460595091702): memmrk:    20832540    34911104
xdk:client:[2016-04-14T00:51:32.155Z]: (1460595092155): memmrk:    43490256    58353664
xdk:server:[2016-04-14T00:51:36.702Z]: (1460595096702): memmrk:    20840820    34911104
xdk:client:[2016-04-14T00:51:37.155Z]: (1460595097155): memmrk:    43654296    58353664
xdk:server:[2016-04-14T00:51:41.702Z]: (1460595101702): memmrk:    20851096    34911104
xdk:client:[2016-04-14T00:51:42.156Z]: (1460595102156): memmrk:    43757880    58353664
xdk:server:[2016-04-14T00:51:46.702Z]: (1460595106702): memmrk:    20859108    34911104
xdk:client:[2016-04-14T00:51:47.157Z]: (1460595107157): memmrk:    43912092    58353664
xdk:server:[2016-04-14T00:51:51.703Z]: (1460595111704): memmrk:    20866144    34911104
xdk:client:[2016-04-14T00:51:52.158Z]: (1460595112158): memmrk:    44016668    58353664
xdk:server:[2016-04-14T00:51:56.704Z]: (1460595116704): memmrk:    20885088    34911104
xdk:client:[2016-04-14T00:51:57.158Z]: (1460595117158): memmrk:    44187572    58353664
xdk:server:[2016-04-14T00:52:01.704Z]: (1460595121704): memmrk:    20893980    34911104
xdk:client:[2016-04-14T00:52:02.158Z]: (1460595122158): memmrk:    44291156    58353664
xdk:server:[2016-04-14T00:52:06.705Z]: (1460595126705): memmrk:    20901016    34911104
xdk:client:[2016-04-14T00:52:07.159Z]: (1460595127159): memmrk:    44445344    58353664
xdk:server:[2016-04-14T00:52:11.705Z]: (1460595131705): memmrk:    20908068    34911104
xdk:client:[2016-04-14T00:52:12.159Z]: (1460595132159): memmrk:    44551472    58353664
xdk:server:[2016-04-14T00:52:16.705Z]: (1460595136705): memmrk:    20915088    34911104
xdk:client:[2016-04-14T00:52:17.161Z]: (1460595137161): memmrk:    44705644    58353664
xdk:server:[2016-04-14T00:52:21.705Z]: (1460595141705): memmrk:    20922108    34911104
xdk:client:[2016-04-14T00:52:22.162Z]: (1460595142162): memmrk:    44809244    58353664
xdk:server:[2016-04-14T00:52:26.706Z]: (1460595146706): memmrk:    20929128    34911104
xdk:client:[2016-04-14T00:52:27.162Z]: (1460595147162): memmrk:    44963432    58353664
xdk:server:[2016-04-14T00:52:31.707Z]: (1460595151707): memmrk:    20936164    34911104
xdk:client:[2016-04-14T00:52:32.162Z]: (1460595152162): memmrk:    45068624    58353664
xdk:server:[2016-04-14T00:52:36.707Z]: (1460595156707): memmrk:    20943200    34911104
xdk:client:[2016-04-14T00:52:37.163Z]: (1460595157163): memmrk:    45086872    58353664
xdk:server:[2016-04-14T00:52:41.707Z]: (1460595161707): memmrk:    20950220    34911104
xdk:client:[2016-04-14T00:52:42.163Z]: (1460595162163): memmrk:    45224584    58353664
xdk:server:[2016-04-14T00:52:46.708Z]: (1460595166708): memmrk:    20957240    34911104
xdk:client:[2016-04-14T00:52:47.164Z]: (1460595167164): memmrk:    45381700    58353664
xdk:server:[2016-04-14T00:52:51.709Z]: (1460595171709): memmrk:    20963352    34911104
xdk:client:[2016-04-14T00:52:52.164Z]: (1460595172164): memmrk:    43283532    58353664
xdk:server:[2016-04-14T00:52:56.709Z]: (1460595176709): memmrk:    20970388    34911104
xdk:client:[2016-04-14T00:52:57.165Z]: (1460595177165): memmrk:    43479528    58353664
xdk:server:[2016-04-14T00:53:01.709Z]: (1460595181709): memmrk:    20977408    34911104
xdk:client:[2016-04-14T00:53:02.165Z]: (1460595182165): memmrk:    43594092    58353664
xdk:server:[2016-04-14T00:53:06.709Z]: (1460595186709): memmrk:    20984444    34911104
xdk:client:[2016-04-14T00:53:07.165Z]: (1460595187165): memmrk:    43079784    52173056
xdk:server:[2016-04-14T00:53:11.709Z]: (1460595191710): memmrk:    20991480    34911104
xdk:client:[2016-04-14T00:53:12.166Z]: (1460595192166): memmrk:    43187712    52173056
xdk:server:[2016-04-14T00:53:16.709Z]: (1460595196709): memmrk:    20998500    34911104
xdk:client:[2016-04-14T00:53:17.167Z]: (1460595197167): memmrk:    43347352    52173056
xdk:server:[2016-04-14T00:53:21.709Z]: (1460595201709): memmrk:    21008296    34911104
xdk:client:[2016-04-14T00:53:22.167Z]: (1460595202167): memmrk:    42939980    52173056
xdk:server:[2016-04-14T00:53:26.709Z]: (1460595206709): memmrk:    21015316    34911104
xdk:client:[2016-04-14T00:53:27.167Z]: (1460595207167): memmrk:    43133136    52173056
xdk:server:[2016-04-14T00:53:31.709Z]: (1460595211709): memmrk:    21024572    34911104
xdk:client:[2016-04-14T00:53:32.167Z]: (1460595212167): memmrk:    42474300    52173056
xdk:server:[2016-04-14T00:53:36.710Z]: (1460595216710): memmrk:    21031592    34911104
xdk:client:[2016-04-14T00:53:37.168Z]: (1460595217168): memmrk:    42719472    52173056
xdk:server:[2016-04-14T00:53:41.710Z]: (1460595221710): memmrk:    21038628    34911104
xdk:client:[2016-04-14T00:53:42.168Z]: (1460595222168): memmrk:    42828112    52173056
xdk:server:[2016-04-14T00:53:46.710Z]: (1460595226710): memmrk:    21045648    34911104
xdk:client:[2016-04-14T00:53:47.169Z]: (1460595227169): memmrk:    42648608    52173056
xdk:server:[2016-04-14T00:53:51.710Z]: (1460595231710): memmrk:    21052668    34911104
xdk:client:[2016-04-14T00:53:52.169Z]: (1460595232169): memmrk:    42724904    53221632
xdk:server:[2016-04-14T00:53:56.711Z]: (1460595236711): memmrk:    21059688    34911104
xdk:client:[2016-04-14T00:53:57.170Z]: (1460595237170): memmrk:    41432016    53221632
xdk:server:[2016-04-14T00:54:01.711Z]: (1460595241711): memmrk:    21153468    34911104
xdk:client:[2016-04-14T00:54:02.170Z]: (1460595242170): memmrk:    41630052    53221632
xdk:server:[2016-04-14T00:54:06.711Z]: (1460595246711): memmrk:    21161856    34911104
xdk:client:[2016-04-14T00:54:07.170Z]: (1460595247170): memmrk:    41785316    53221632
xdk:server:[2016-04-14T00:54:11.712Z]: (1460595251712): memmrk:    21168892    34911104
xdk:client:[2016-04-14T00:54:12.171Z]: (1460595252171): memmrk:    41888804    53221632
xdk:server:[2016-04-14T00:54:16.711Z]: (1460595256711): memmrk:    21175928    34911104
xdk:client:[2016-04-14T00:54:17.172Z]: (1460595257172): memmrk:    42043540    53221632
xdk:server:[2016-04-14T00:54:21.712Z]: (1460595261712): memmrk:    21182948    34911104
xdk:client:[2016-04-14T00:54:22.172Z]: (1460595262172): memmrk:    42148416    53221632
xdk:server:[2016-04-14T00:54:26.712Z]: (1460595266712): memmrk:    21189968    34911104
xdk:client:[2016-04-14T00:54:27.173Z]: (1460595267173): memmrk:    42306932    53221632
xdk:server:[2016-04-14T00:54:31.712Z]: (1460595271712): memmrk:    21201192    34911104
xdk:client:[2016-04-14T00:54:32.174Z]: (1460595272174): memmrk:    42414264    53221632
xdk:server:[2016-04-14T00:54:36.713Z]: (1460595276713): memmrk:    21208212    34911104
xdk:client:[2016-04-14T00:54:37.174Z]: (1460595277174): memmrk:    42578552    53221632
xdk:server:[2016-04-14T00:54:41.713Z]: (1460595281713): memmrk:    21233728    34911104
xdk:client:[2016-04-14T00:54:42.174Z]: (1460595282174): memmrk:    41947564    53221632
xdk:server:[2016-04-14T00:54:46.713Z]: (1460595286713): memmrk:    21254612    34911104
xdk:client:[2016-04-14T00:54:47.175Z]: (1460595287175): memmrk:    42101464    53221632
xdk:server:[2016-04-14T00:54:51.713Z]: (1460595291713): memmrk:    21263624    34911104
xdk:client:[2016-04-14T00:54:52.175Z]: (1460595292175): memmrk:    42208872    53221632
xdk:server:[2016-04-14T00:54:56.714Z]: (1460595296714): memmrk:    21279052    34911104
xdk:client:[2016-04-14T00:54:57.175Z]: (1460595297175): memmrk:    42362772    53221632
xdk:server:[2016-04-14T00:55:01.714Z]: (1460595301714): memmrk:    21287012    34911104
xdk:client:[2016-04-14T00:55:02.176Z]: (1460595302176): memmrk:    42466696    53221632
xdk:server:[2016-04-14T00:55:06.714Z]: (1460595306714): memmrk:    21314160    34911104
xdk:client:[2016-04-14T00:55:07.178Z]: (1460595307178): memmrk:    42623072    53221632
xdk:server:[2016-04-14T00:55:11.714Z]: (1460595311714): memmrk:    21321012    34911104
xdk:client:[2016-04-14T00:55:12.179Z]: (1460595312179): memmrk:    42743360    53221632
xdk:server:[2016-04-14T00:55:16.714Z]: (1460595316714): memmrk:    21331408    34911104
xdk:client:[2016-04-14T00:55:17.179Z]: (1460595317179): memmrk:    42348568    55318784
xdk:server:[2016-04-14T00:55:21.715Z]: (1460595321715): memmrk:    21338244    34911104
xdk:client:[2016-04-14T00:55:22.180Z]: (1460595322180): memmrk:    42469116    55318784
xdk:server:[2016-04-14T00:55:26.715Z]: (1460595326715): memmrk:    21345096    34911104
xdk:client:[2016-04-14T00:55:27.180Z]: (1460595327180): memmrk:    42630476    55318784
xdk:server:[2016-04-14T00:55:31.715Z]: (1460595331715): memmrk:    21351932    34911104
xdk:client:[2016-04-14T00:55:32.180Z]: (1460595332180): memmrk:    42733868    55318784
xdk:server:[2016-04-14T00:55:36.715Z]: (1460595336715): memmrk:    21358768    34911104
xdk:client:[2016-04-14T00:55:37.182Z]: (1460595337182): memmrk:    42887752    55318784
xdk:server:[2016-04-14T00:55:41.715Z]: (1460595341715): memmrk:    21365604    34911104
xdk:client:[2016-04-14T00:55:42.181Z]: (1460595342181): memmrk:    42991160    55318784
xdk:server:[2016-04-14T00:55:46.715Z]: (1460595346715): memmrk:    21372440    34911104
xdk:client:[2016-04-14T00:55:47.182Z]: (1460595347182): memmrk:    43145060    55318784
xdk:server:[2016-04-14T00:55:51.716Z]: (1460595351716): memmrk:    21379276    34911104
xdk:client:[2016-04-14T00:55:52.183Z]: (1460595352183): memmrk:    43602304    55318784
xdk:server:[2016-04-14T00:55:56.716Z]: (1460595356716): memmrk:    21386128    34911104
xdk:client:[2016-04-14T00:55:57.184Z]: (1460595357184): memmrk:    43959800    56322304
xdk:server:[2016-04-14T00:56:01.716Z]: (1460595361716): memmrk:    21392964    34911104
xdk:client:[2016-04-14T00:56:02.185Z]: (1460595362185): memmrk:    44251460    56322304
xdk:server:[2016-04-14T00:56:06.717Z]: (1460595366717): memmrk:    21401396    34911104
xdk:client:[2016-04-14T00:56:07.186Z]: (1460595367186): memmrk:    45304124    56322304
xdk:server:[2016-04-14T00:56:11.717Z]: (1460595371717): memmrk:    21410452    34911104
xdk:client:[2016-04-14T00:56:12.186Z]: (1460595372186): memmrk:    44076604    57337984
xdk:server:[2016-04-14T00:56:16.717Z]: (1460595376717): memmrk:    21417288    34911104
xdk:client:[2016-04-14T00:56:17.188Z]: (1460595377188): memmrk:    44230508    57337984
xdk:server:[2016-04-14T00:56:21.717Z]: (1460595381717): memmrk:    21424124    34911104
xdk:client:[2016-04-14T00:56:22.188Z]: (1460595382188): memmrk:    44333916    57337984
xdk:server:[2016-04-14T00:56:26.718Z]: (1460595386718): memmrk:    21894672    34911104
xdk:client:[2016-04-14T00:56:27.192Z]: (1460595387192): memmrk:    45733084    57337984
client:build-tab:[2016-04-14T00:56:27.370Z]: (1460595387370): [updatePageState] Set State: PAGE_STATE_PREPARING
client:build-tab:[2016-04-14T00:56:27.371Z]: (1460595387371): [uploadBuildAssets] Uploading project files
xdk:server:[2016-04-14T00:56:31.719Z]: (1460595391719): memmrk:    35538384    51556736
xdk:client:[2016-04-14T00:56:32.194Z]: (1460595392194): memmrk:    44114256    62547968
xdk:server:[2016-04-14T00:56:36.721Z]: (1460595396721): memmrk:    43936184    58666496
xdk:client:[2016-04-14T00:56:37.194Z]: (1460595397194): memmrk:    44272680    62547968
xdk:server:[2016-04-14T00:56:41.736Z]: (1460595401736): memmrk:    28575768    59682176
xdk:client:[2016-04-14T00:56:42.195Z]: (1460595402195): memmrk:    48550372    63551488
client:build-tab:[2016-04-14T00:56:42.431Z]: (1460595402431): [updatePageState] Set State: PAGE_UPLOADING_PROJECT
xdk:server:[2016-04-14T00:56:46.737Z]: (1460595406737): memmrk:    37012244    59682176
xdk:client:[2016-04-14T00:56:48.120Z]: (1460595408120): memmrk:    42948356    68905216
Node Webkit Error log:
[37272:0413/214825:INFO:CONSOLE(17)] ""xdk:client:[2016-04-14T00:48:25.785Z]: (1460594905785): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/214842:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (212)
[37272:0413/214843:INFO:CONSOLE(17)] ""client:build-tab:[2016-04-14T00:48:43.032Z]: (1460594923032): [refreshPage] Unable to generate project hash." {"message_":"Cannot generate app id without user identifiers","code_":null,"componentName_":null,"stack_":"Error\n    at Object.createXdkAppId (D:\\Intel XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n    at Object.exports.generateProjectHash (file:///D:/Intel%20XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n    at _refreshPage (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:796:13)\n    at D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:604:44","httpCode_":400}", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/214843:INFO:CONSOLE(17)] ""builds:[2016-04-14T00:48:43.162Z]: (1460594923163): Error building UI for: certificateId"", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/215642:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///D:/Intel%20XDK/xdk/public/index-node-webkit.html (0)
[37272:0413/215647:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///D:/Intel%20XDK/xdk/public/index-node-webkit.html (0)
[37272:0413/215648:ERROR:ipc_channel_reader.cc(65)] IPC message is too big
[37272:0413/215648:INFO:dispatcher_host.cc(157)] [NW.JS]RenderProcessGone
XDK exit code & signal: 258, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash minidump NOT FOUND.
NW Crash Detected.
Amrita_C_Intel
It might be possible the resources your using in the app might be too large. Like an image which might be too large. Remove such resources and build it again.
PaulF_IntelCorp
Guillermo -- how big is your project folder and all the folders and files contained within? Can you build one of the sample apps? Is your problem limited to this project or do all apps (including the sample apps) cause the XDK to crash?
