Software Archive
Read-only legacy content
17060 Discussions
XDK vs Android 5.0.2 Lollipop
Tiago_D_1
Olá,
Estou passando por alguns problemas com a compilação do projeto XDK.
Testando em diversos sistemas operacionais, resultando na mesma situação.
Testando em diversos aparelhos com ANDROID 5.0.2 'LOLLIPOP' encontramos a mesma situação.
Resolvi aplicar a um ANDROID 4.4 e ficou intermediário;
O Problema:
Quando compilo o APK e passo para aparelhos com ANDROID 5.0.2, os "ícones" e "botões" ficam visivelmente "minúsculos", quase impossível pressionar.
Tem a ver mesmo com a versão do ANDROID??
Existe alguma forma de suportar APK no Android 5.0.2 Lollipop?
Aguardo.
PaulF_IntelCorp
I am going through some problems with compiling the XDK project.
Testing on multiple operating systems, resulting in the same situation .
Testing on multiple devices with ANDROID 5.0.2 ' LOLLIPOP ' we find the same situation.
I decided to apply to a ANDROID 4.4 and was intermediate ;
The Problem:
When you compile the APK and step for devices with ANDROID 5.0.2 , the " icons " and " buttons " are visibly " tiny " almost impossible to press .
It has to do with the same version of ANDROID ??
Is there any way to support APK Android 5.0.2 Lollipop ?
Based on your description, I'm guessing that you are building for Android rather than building for Crosswalk. You are probably seeing differences that result from different versions of webviews on the devices. Building for embedded Crosswalk (recommend 14) will give you consistent results across devices. Please see these articles for more details:
Tiago_D_1
The Problem:
Perfeito,
Não havia me aprofundado em CrossWalk.
Deu certo por enquanto...
Vou continuar os testes.
Obrigado.
PaulF_IntelCorp
You're welcome.
