Software Archive
Read-only legacy content
17060 Discussions
XEON - WaitableTimer Resolution
charles_stuart
The waitabletimer resolution seems to be 16 ms on a 3.2 Ghz XEON processor. The minimum period seems to be 16 ms, while on a Pentium system the resolution is 1 ms. Is it possible to have my HP XEON workstation have increased resolution? I need a 5 ms timer.
teresa
I have escalated this and will let you know when I get a response.
teresa
Not surewhat OS you have, but here's some pointers from our engineering team:
On Windows* - QueryPerformanceCounter api call is able to go down to a microsecond resolution or use the multimedia timer APIs these are documented on MSDN*. The other option is to read the rdtsc register directly.This goes well below microsecond granularity (on Intel Xeon Processor it is ~100 cycles per read).
On Linux* - gettimeofday has a microsecond resolution also. So this could be an option.
Hope this helps.
Teresa R.
Intel Software Network Support
http://www.intel.com/software
Contact us
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
Message Edited by intel.software.network.support on 11-15-2005 08:40 PM
nick_arn
//#include
//#pragma comment (lib,"winmm.lib")
TIMECAPS tc;
timeGetDevCaps(&tc,
sizeof(TIMECAPS));
MMRESULT mr=timeBeginPeriod(tc.wPeriodMin);
//usually, you can increase it to 1 ms :-)
