Software Archive
Read-only legacy content
17060 Discussions
Xeon Phi 31S1P 270W vs 300W
Minh_H_
System: Ubuntu 14.03, MPSS 3.4.1, 31S1P
When I run micinfo it display "Product 300W Passive CS" instead of 270W as product description. Is it a "feature" or a bug?
System Info
        HOST OS            : Linux
        OS Version        : 3.13.0-44-generic
        Driver Version        : 3.4.2-1
        MPSS Version        : NotAvailable
        Host Physical Memory    : 264047 MB
Device No: 0, Device Name: mic0
    Version
        Flash Version          : 2.1.02.0390
        SMC Firmware Version     : 1.16.5078
        SMC Boot Loader Version     : 1.8.4326
        uOS Version          : 2.6.38.8+mpss3.4.1
        Device Serial Number      : ADKC31700474
    Board
        Vendor ID          : 0x8086
        Device ID          : 0x225e
        Subsystem ID          : 0x2500
        Coprocessor Stepping ID     : 3
        PCIe Width          : x16
        PCIe Speed          : 5 GT/s
        PCIe Max payload size     : 256 bytes
        PCIe Max read req size     : 512 bytes
        Coprocessor Model     : 0x01
        Coprocessor Model Ext     : 0x00
        Coprocessor Type     : 0x00
        Coprocessor Family     : 0x0b
        Coprocessor Family Ext     : 0x00
        Coprocessor Stepping      : B1
        Board SKU          : B1PRQ-31S1P
        ECC Mode          : Enabled
        SMC HW Revision      : Product 300W Passive CS
    Cores
        Total No of Active Cores : 57
        Voltage          : 1093000 uV
        Frequency         : 1100000 kHz
    Thermal
        Fan Speed Control      : N/A
        Fan RPM          : N/A
        Fan PWM          : N/A
        Die Temp         : 40 C
    GDDR
        GDDR Vendor         : Elpida
        GDDR Version         : 0x1
        GDDR Density         : 2048 Mb
        GDDR Size         : 7936 MB
        GDDR Technology         : GDDR5
        GDDR Speed         : 5.000000 GT/s
        GDDR Frequency         : 2500000 kHz
        GDDR Voltage         : 1501000 uV
Frances_R_Intel
At first I was also concerned that the output said "MPSS Version : NotAvailable" but then I noticed that you were running Ubuntu and realized that this only meant it didn't find the rpm file - no surprise there.
As far as the 300W value, this is a known issue. It is not that the power really is 300W but that the SMC output is not being correctly interpreted. There was a work around in an earlier version of the micinfo code, but it seems to no longer be working. I'll submit a new bug report to let the developers know. (HSD 5162215)
