Software Archive
Read-only legacy content
17060 Discussions
Xeon Phi Performance Question
Jonathan_J_
We have a current software application that we currently only run a single instance of at once.  It requires no user input, simply runs for a pre-defined amount of time essentially navigating through a flowchart and spitting out data.  However, we desire to run multiple (100+) instances of it at once.  It is a relatively complicated program, with a decent amount of branching as it decides what to do with each node as it reaches it.  There is no current memory bandwidth issues, either.  However, it is technically running the same code in parallel... does that mean it can take advantage of SIMD? Or does SIMD only apply to simple instructions, like multiplication and addition?
Sumedh_N_Intel
Copy of Topic#401168.
