Software Archive
Read-only legacy content
17060 Discussions
about getting response from jsp
Jagannadh_K_
I was developing barcode scanning app ,the theme of app is to scan the barcode and send it to jsp , in our application server. it is reaching the jsp ,but the response code is not coming as 0,
-------------bcsamp.jsp-------------------
<%@ page contentType="text/html; charset=iso-8859-1" language="java" import="java.sql.*,java.io.*,java.util.*,java.text.*,javax.sql.*,javax.servlet.*,javax.servlet.http.*,javax.naming.*,javax.naming.directory.*" errorPage="" %>
String bcodstr=request.getParameter("bcstr");
System.out.println("bcodstrval"+bcodstr);
if(!(bcodstr.equals("")))
System.out.println("Success"+bcodstr);
out.println("Success");
else
out.println("Please scan again");
System.out.println("fail"+bcodstr);
-------jsp ends here-------------
------------barcode scan function in XDK app-------------
function scan() {
    "use strict";
    var fName = "scan():";
    console.log(fName, "entry");
    try {
        if (window.tinyHippos) {
            thirdPartyEmulator();
            console.log(fName, "emulator alert");
        } else {
            cordova.plugins.barcodeScanner.scan(
                function (result) {
                    console.log(fName, "Scanned result found!");
                    var xhttp = new XMLHttpRequest();
                    xhttp.onreadystatechange = function() {
                        alert("s"+xhttp.readyState);
                        alert("om"+xhttp.status);
                    if (xhttp.readyState == 4 || xhttp.status == 200)
                       alert(xhttp.responseText);
                        if(xhttp.readyState != 4 || xhttp.status == 404)
                            alert("Web Service Doesn't Exist");
                    //var xhr = new XMLHttpRequest();
                    var urlo="http://XXX.XX.XX.XX/APPLICATIONSAMP/bcsmap.jsp?bcstr="+result.text;
                    //var urlo="http://google.co.in";
                    //alert(urlo);
                    //xhr.open("GET",urlo,true);
                    //xhr.send(null);
                    xhttp.open("GET",urlo, true);
                    xhttp.send();
                    /*xhr.onload=function()
                    {alert("resp status"+xhr.status);
                    alert("resp status1"+xhr.responseText);
                    alert("resp status2"+xhr.readyState);
                /*alert("We got a barcode!\n" +
                        "Result: " + result.text + "\n" +
                        "Format: " + result.format + "\n" +
                        "Cancelled: " + result.cancelled + "\n\n" +
                        "You may use the " + result.format + " - '" + result.text + "' to look up your product in any UPC database like http://www.upcdatabase.com/");*/
                function (error) {
                    alert("Scanning failed: " + error);
    } catch (e) {
        console.log(fName, "catch, failure");
    console.log(fName, "exit");
-------------in this scanning works but response from jsp is not getting.
PaulF_IntelCorp
Do not use the Emulate tab for testing something like barcode, use a real Android device in conjunction with the Debug tab.
Jagannadh_K_
i build the app and installed in my phone and tested it,the response code is coming as 0, it is not getting the response from jsp
PaulF_IntelCorp
Have you tried the barcode sample that is in the "Samples and Demos" section of the "Start a New Project" in the XDK?
Jagannadh_K_
I am trying using that sample only. But in that sample it is up to scanning only, but I need to send the scanned data to my server, up to scanning it is working fine
PaulF_IntelCorp
There is an XDK article somewhere about making AJAX calls. The best thing to do would be to "google" something like "send JSON data to web server in cordova phonegap app"
