Hi ,
<intent-filter> <action android:name="android.intent.action.SEND" /> <category android:name="android.intent.category.DEFAULT" /> <data android:mimeType="text/plain" /> </intent-filter>
the Android section of the intel.config.additions.xml
<platform name="android">
<!-- below requires the splash screen plugin -->
<!-- docs: https://github.com/apache/cordova-plugin-splashscreen -->
<preference name="SplashMaintainAspectRatio" value="false" />
<intent-filter>
</intent-filter>
</platform>
- Tags:
- HTML5
- Intel® XDK
You can find the information you need for updating the Android manifest file here at https://software.intel.com/en-us/xdk/faqs/general#android-manifest.
Elroy,
So based on that link, I have to created a dummy plugin? So the intelxdk.config.additions.xml is no longer being used?
Or is it the the intelxdk.config.additions.xml will not work for what I need to do?
Mike
The intelxdk.config.additions.xml file is still used, it simply cannot handle what you are trying to do. The additions file is roughly equivalent to the standard Cordova CLI config.xml file, which is used to configure options in the Cordova build. Plugins allow you to do things that are extend the runtime environment and go deeper into the build process than the config.xml file can.
Understood,
I found how to do it here in case anyone is looking to add a intent-filter to the manifest for a plugin.
In short I added it to the plugin's XML file.
Mike
