Software Archive
Read-only legacy content
17060 Discussions
admob plugins - need help
rahul_p_
HI Team,
I exported html5 from construct 2 and then added cranberry/admob plugin and exported to android. No ads are displayed on the application. Please help me where I should edit the admob ad unit it in the plugin. I have a help folder under plugin and there is test/index.html. Please help where i neet to set the ads id and how to edit the configuration file. I saw index.html in test folder. Please assist with the actual path for inserting ad unit id's.
Rahul
rahul_p_
Hi Dale,
Thank you for the links. Adding to my first post , I imported the code and the cranberry plugin, but not sure where exactly i need to enter the ad unit id . Is it in www/index.html or test/index.html. Please assist.
Rahul
Elroy_A_Intel
Here is an example using this Cordova plugin and declaring the ad unit id: https://github.com/cranberrygame/phonegap-plugin-ad-admob/blob/master/example/basic/index.html#L9
Dale_S_Intel
I haven't tried it myself yet, but here's an example:
It looks like it's included in the call to admod.setUp:
window.admob.setUp(bannerAdUnit, fullScreenAdUnit, isOverlap, isTest);
