Software Archive
Read-only legacy content
allocate()
Intel_C_Intel
Is there a way to make allocate() used the address starting from a
region boundary(64KB) and end also at region boundary? I don't care it may waste some memory. Or if someone can give me an equivalent code using malloc() to realized allocate().
Thank you so much.
dppvlit
The easy way to do this is to allocate 64KB more than you want and round the returned address up to the next 64KB boundary.
I don't recommend using ALLOCATE for this, as the address computation is not under your control, but using malloc it should be easy enough.
A better bet might be the Win32 API routine VirtualAlloc, passing NULL as the lpAddress argument, since this operates in units of 64KB pages anyway.
Steve
Intel_C_Intel
I guess I didn't state the problem clearly.
There is a user defined TYPE of allocatable arrays (or pointer). I used allocate() to allocate memory for it. If I used VirtualAlloc, how do I pass the returned address to the pointer or the array so that later references to them behave correctly, just like allocate() does?
dppvlit
Intel_C_Intel
For example: Is the following code legal?
Do I need typecast before malloc()?
type (MYTYPE), pointer :: pMyType
pMyType => malloc(SIZEOF(MYTYPE))
No. You need to do this instead:
type(MYTYPE) :: MyTypeThing
pointer (pMyType, MyTypeThing)
pMyType = malloc(sizeof(MyTypeThing))
Note the use of the non-standard integer pointer feature, not the Fortran 90 POINTER which is different.
Steve
