Software Archive
Read-only legacy content
17060 Discussions
buffer write failed
nikolaos_s_1
I am trying to offload a whole program on mic by doing the following:
int mymain(int argc,char *argv[]){
 int main(int argc,char *argv[]){
#pragma offload target(mic) in(argv:length(argc))
mymain(argc,argv);
I get the following error:
offload error: buffer write failed (error code 6)
Could you please help me?
Best,
Nikos
Ravi_N_Intel
which version of the compiler are you using.
with 16.0 compiler I do not get the error
 cat test.c
__declspec(target(mic))
  printf("hello world\n");
mymain(argc,argv);
icc test.c
test.c(3): warning #266: *MIC* function "printf" declared implicitly
 ./a.out
hello world
nikolaos_s_1
Hello Ravi,
Thank you for the immediate response, it turned out to be a reference to an extern variable that was resolved when i defined a local copy of that variable.
